JVC Autocal using ColourSpace Remote Control
#31 | Posted: 31 Jan 2022 18:17
Omardris
That is great news!!!
Author stuart_p
#32 | Posted: 2 Feb 2022 08:58
Thanks for this Ted and Omardis. Be very interested to see how it goes, I'll let you know how I go.
Stuart
Author Omardris
#33 | Posted: 15 Nov 2023 14:59
I would like to point out that the interface between JVC-AutoCal and the remote control from ColourSpace also works with the current version of JVC-AutoCal 13 v1.20.
The user only has to copy the alternative files into the program directory of JVC-AutoCal 13 v1.20 according to the instructions (Quickstart.pdf).
Peter
Author Omardris
#34 | Posted: 1 Aug 2026 16:10
New Version of the JVC-Autocal Adjustment for ColourSpace
I have revised the remote connection from JVC-Autocal to ColourSpace.
The goal of this interface is to enable the use of all sensors supported by the respective version of ColourSpace with JVC-Autocal.
The selection of sensors depends on the ColourSpace license.
The settings, correction methods, etc., provided in ColourSpace for each sensor are applied.
There are two new versions of the customisation:
"CS_4_autocal_v3" for JVC-Autocal 14v1.2 and earlier, i.e., the older JVC projectors and models NZ500 through NZ900.
Quick Guide for CS_4_autocal_v3:
https://magentacloud.de/s/Bmgttr5wYt4L4ZG
"CS_4_autocal_v5" for JVC-Autocal 14v2.0 and later, meaning it is only for the current JVC projectors NZ500 through NZ900.
Quick Start Guide for CS_4_autocal_v5:
https://magentacloud.de/s/W3PwksB9m9tBFPj
All ColourSpace license levels, including ZRO (32-bit & 64-bit), are supported.
Both versions of CS_4_autocal require a license file, which costs 10 euros.
Without a license, you can establish a connection to ColourSpace for testing purposes, but you cannot take any measurements.
Please read the quick start guide for more information.
Distribution of the older ColourSpace calibration via displaycalibrations.com (TED) has ended. Thank you very much for your support.
Feel free to contact me via PM or email (videoarte@t-online.de) for further details.
Author CIR Engineering
#35 | Posted: 7 Sep 2026 17:36
Hi all. I have been happily calibrating using your files for many years Omardris. Unfortunately, my laptop broke and I have had to migrate to a new laptop. Upon doing so, the dll files I have no longer work. I also perhaps need a new dll file because I upgraded JVC autocal to v14.2. I have thoroughly read through the linked quickstart guides above. I cannot figure out where to get the required download files listed in the quickstart guids; "dc24Test.exe" and "dc24mtr.dll" for v14.2.0 and files "dcTest.exe" "dccmtr.dll" "dcxmtr.dll" for the older versions of JVC autocal.
I really need to sort this out as I am calibrating an NZ900 tomorrow. I could use some help please.
#36 | Posted: 7 Sep 2026 17:44
https://lightillusion.com/addons.html
Do you mean JVC Autocal there?
There is a 'Request Access' button.
#37 | Posted: 7 Sep 2026 17:55
It looks that way Steve. I had working dll's before that I paid Omardris for way way back near the beging of his programming. But they are not working now on my new laptop. Via your link, I can click "JVC Autocal" and then "Request Access", which brings up an email form to videoarte@t-online.de. Is this correct and should I just send an email?
Sorry I am so confused. I've found bits and bobs on different forums scattered across the internet forums. I've used the Same dll's on two or three computers since the begging, but now they don't works and I am out of the look so to speak.
Thank you.
Craig
#38 | Posted: 7 Sep 2026 17:59
Yes, the same email address is in the the post above your first one too.
#39 | Posted: 7 Sep 2026 18:00
I just sent an email. Who answers it Steve? I really hope I can get this squared away today so I can do an autocal tomorrow.
#40 | Posted: 7 Sep 2026 18:02
Ah OK thank you. I have long since deleted my emails with "Omardris" and no longer had it.
#41 | Posted: 7 Sep 2026 18:20
"Omardris" responded to my email. I'm set. Thanks for pointing me in the right place Steve.
Online now: Guests - 6
Members - 1 [ twitt88 ]
