New Software Releases Light Illusion Forums / New Software Releases /
Correlation Files for Calibrite/Xrite Colorimeters
Page  Page 10 of 10 :  « Previous  1  2  3  4  5  6  7  8  9  10
#136 | Posted: 16 Sep 2026 07:21
As RollsRoyce says, Using a reliable 10nm spectro, such as i1Pro or Myiro-1 is better than using any EDR/CCSS/Correlation File.
But as ConnecTED say, the ColorMunki is not a reliable spectro.
And any EDR/CCSS/Correlation File are really NOT any guarantee of accuracy, as stated HERE.
Author mga2009
#137 | Posted: 16 Sep 2026 15:41
ConnecTED
Thanks all for the information.
ZRO cannot work with Colormunki Photo?
#138 | Posted: 16 Sep 2026 16:37
mga2009
That meter doesn't work with any ColourSpace license.
#139 | Posted: 6 Oct 2026 21:25
Correlation Files for Calibrite/X-Rite Colorimeters (07 October 2026 Update)
Added the following spectral correction files:
EIZO ColorEdge CG3200X (RGB QD-OLED) - Colorimetry Research CR-250 4nm
TVLogic LVM-242S (IPS LCD) - Colorimetry Research CR-250 4nm
The ZIP contains the following 199 Spectral Correlation files:
Instructions
Download Link: ColorChecker-i1D3 Spectral CVS Files (07 October 2026)
Author Alexey
#140 | Posted: 10 Oct 2026 05:52
Hi, Ted!
The SPD file list contains 2 files for the same TCL X11L TV, measured with different spectroradiometers (CR‑300 and OHSP‑350). If you open them simultaneously on the same graph, you will clearly observe a shift of exactly 4 nanometers in the OHSP‑350 reading relative to the CR‑300 — the OHSP‑350 reading is higher.
Should the SPD reading from the spectroradiometer be adjusted by 4 nanometers for use in calibration? And what could cause such a shift?
Sincerely, Alexey!
#141 | Posted: 10 Oct 2026 17:14
Initially, one user contributed the OHSP-350, followed by another user who provided the CR-300.
It's obvious someone will choose the CR-300; I kept both to respect the first user's effort, who spent time and wanted to help by providing those measurements so that ColourSpace users of i1d3 could benefit.
#142 | Posted: 10 Oct 2026 18:31
The OHSP-350 Correlation File issue probably means there is a bug in the data output from that probe/program.
It may just be in the exported file.
Or it may be a genuine issue with the probe.
Someone would have to ask the manufacturer for verification.
Author Alexey
#143 | Posted: 10 Oct 2026 19:32
I also own the same sensor. I created a spectral power SPD file for the BenQ SW270C monitor. I compared it with the SPD from Ted's set. My SPD differed by 2 nanometers across all peaks.
I'd like to understand what the nature of this shift in nanometers is.
#144 | Posted: 10 Oct 2026 20:00
You are going to have to talk to the manufacturer...
#145 | Posted: 12 Oct 2026 13:38
The CR-300 has a claimed spectral accuracy of+/- 0.3nm, while the OHSP-350 claims +/- 0.5nm. This might account for some of that offset if both meters are at opposite ends of their specifications.
Author Alexey
#146 | Posted: 14 Oct 2026 10:38
I would be very grateful if someone could create a spectral power file for the Asus ProArt PA27UCGE using a high‑end spectrometer.
#147 | Posted: 14 Oct 2026 22:03
Correlation Files for Calibrite/X-Rite Colorimeters (14 October 2026 Update)
We fixed an error in the first raw data and then re-uploaded the updated spectral correction files:
Apple Pro Display XDR - Colorimetry Research CR-250 4nm
Panasonic W90A (Direct LED) - Colorimetry Research CR-250 4nm
Instructions
Download Link: ColorChecker-i1D3 Spectral CVS Files (14 October 2026)
