TCL TV calibration.
Page  Page 4 of 6 :  « Previous  1  2  3  4  5  6  Next »
Author NebulaUK Male
#46 | Posted: 4 Jun 2025 23:54
Ok it was a problem with my TCL QM8B I have now got a TCL Q9BK and it worked first time without a hitch and the image looks fantastic.
Thanks for your help and thanks for a great piece of software.
#47 | Posted: 5 Jun 2025 08:55
Do you know what the issue was with the QM8B?
#48 | Posted: 5 Jun 2025 14:34
Sorry I don't but I think it might be firmware related.
#49 | Posted: 5 Jun 2025 14:50
Ok - I've asked TCL if they have any info on that model.
Author foxone Male
#50 | Posted: 1 Sep 2025 07:59
Hi there !
TCL C855 eastern europe
I just installed a week ago (big mistake), the latest firmware version V8-0012T01-LF1V509 in short v509 and I notice that there are problems with the image, especially with Dolby Vision. Before the update, everything looked perfect, but there are problems with Oversaturation and Posterization, especially with skin tones in semi-dark / darknest movies environments or artificial light. I tried changing the brightness, contrast, gamma and other settings, but it doesn't solve much. The same problem with Filmmaker mode. Does anyone know if a newer firmware version is on the way for Eastern Europe and if it solves the image problems? At the moment, Dolby Vision does not support compatibility with Filmmaker mode. The tv has not been and is not calibrated
#51 | Posted: 1 Sep 2025 11:49
foxone
Sorry, but you really will want to contact TCL directly, as this is a forum for Light Illusion software users who wish to calibrate their sets, and not for general display issues. There are other forums far more suited to this kind of inquiry.
Author twitt88
#52 | Posted: 28 Jan 2026 17:20
hi Steve -
I saw your comment that "As the TV is a FALD it is usual to use full screen patterns." curious if that is for SDR only or both SDR and HDR, in your opinion of course? I've done a lot of messing about on my TCL with different window sizes, backgrounds, etc for HDR and really hitting a wall as I can find one that sits on PQ incredibly well (10% on black for example) but doesn't translate well to real content imo or one that feels more visually pleasing (larger window on mid gray bg) but does not look great in charts. In your experience with this type of panel, and I know this is all down to everyone to experiment, but what have you found as your preference to work with in terms of window size and bg when balancing grayscale in HDR?
#53 | Posted: 28 Jan 2026 20:32
Unfortunately, with FALD displays there is no answer.
In reality, it just down t personal preference.
You cannot chase a technically accurate calibration.
Author twitt88
#54 | Posted: 28 Jan 2026 20:48
Completely fair and I appreciate the honesty.
I'm definitely not looking for a "technically correct" answer where one doesn't exist, and I understand why that line can't really be drawn with FALD. I've come to that conclusion myself after quite a bit of trial-and-error across different window sizes, backgrounds, and LD states, and seeing firsthand how differently graphs and real content can behave ha
If you don't mind me reframing slightly: when you personally work with FALD LCDs, do you find HDR behaves more predictably when approached more like SDR (larger or full-field patterns), or do you still tend to anchor HDR grayscale with some form of windowed pattern and accept the translation variance?
Even a high-level "I usually lean toward X in practice" would be helpful context; not as guidance, just perspective.
Thanks again for taking the time to respond.
#55 | Posted: 28 Jan 2026 21:45
I would personally go full screen for FALD.
But that's just my preference.
Author twitt88
#56 | Posted: 28 Jan 2026 22:12
Truly appreciate that perspective.
#57 | Posted: 1 Oct 2026 02:53
I have another question as I'm trying to use spd2matrix to verify some correlation files and potentially use the generated file but when you reset the TV to the default settings to take the measurements to verify what settings does that mean I do a picture reset and turn off the dynamic picture settings turn off local dimming and set the colourspace to native and what mode should this be done under standard or film maker and should I use the bypass luts when doing so. I have a TCL Q9BK.
#58 | Posted: 1 Oct 2026 20:41
Without knowing what the TV was set to when the Correlation File was generated all you can really do is test different settings, and see which, if any, are close to the SPD2Matrix output values.
Unfortunately, all part of the issues with Correlation Files.
Definitely best to get a spectro for your own use.
#59 | Posted: 2 Oct 2026 12:59
Thank you
#60 | Posted: 9 Oct 2026 14:10
I have another question should I calibrate SDR with local dimming off or on. I have calibrated my Q9BK with local dimming on with a 10% window and a gray background (52,52,52) (For generating both my 1d and 3dLUT) and probe matched my i1d3 with an EFI ES2000. Is this the correct way because In some low light scenes it looks weird am I doing something wrong?
 TCL TV calibration.
