TCL TV calibration.
Page  Page 5 of 6 :  « Previous  1  2  3  4  5  6  Next »
#61 | Posted: 9 Oct 2026 14:28
That is a choice only you can make.
With FALD displays there is no right/wrong option.
But, as the various user guides do state, most FALD displays should use a full screen patch size.
But again, that is not a right/wrong decision.
Author NebulaUK Male
#62 | Posted: 9 Oct 2026 14:37
But would that not limit the peak brightness of the display or does that not matter. What approach did you use with your TCL.
#63 | Posted: 9 Oct 2026 14:50
Unfortunately, that is all part of the issue with any display with any type of power limiting ABL.
(As is demanded by many countries now to reduce power consumption.)
So again, there is no single answer.
You really need test to define what works best for you, based on the specific ABL operation of your display.
And unfortunately when that display with ABL type operation is a FALD, you have more issues to overcome...
#64 | Posted: 9 Oct 2026 14:57
Ok thanks for your advice.
#65 | Posted: 3 Nov 2026 18:33
Ok so the method I settled on was having local dimming on high since that is how I view the TV and I profile using a 10% Window and a R52 G52 B52 background. I specified a manual black level for 1dlut of 0.0247 which is the displays native black level (without local dimming on) and reprofiled for the 3dlut using the auto black level. It seems to be ok but the shadow detail seems darker than I would like but maybe I'm just not used to a calibrated display apart from that the image looks fine. Is this an acceptable way of doing it?
#66 | Posted: 3 Nov 2026 20:10
NebulaUK
That sounds absolutely fine to me.
As I say, there are no rules, and your approach makes good sense.
#67 | Posted: 3 Nov 2026 22:06
Thank you
Author LMF9L1576FZ007 Female
#68 | Posted: 4 Nov 2026 07:30
I think the best compromise for TCL will be setting local dimming (Local Dimming) to "Medium" (Medium) instead of "High", to make the operation of the algorithm less aggressive. In order for the local dimming to remain active during profiling, I use a 50% window size with a purely black background. Then, in the case when you turn on a real movie with black bars and dark scenes — the local dimming algorithm is activated and does not "collapse" the shadows.
#69 | Posted: 4 Nov 2026 13:27
Thank you I will try it but the last time I tried medium local dimming low light scenes looked weird but that may have been because of my approach so I will test.
#70 | Posted: 6 Nov 2026 02:22
Ok for whomever it may help the correct settings were a 10% window on a background of 27,27,27 that has worked flawlessly and I'm currently enjoying the results
Author unboundkronic Male
#71 | Posted: 6 Nov 2026 15:59
foxone
Is this the same issue you were having (photos attached)? I have a US TCL 85QM851G (US versions are not LUT compatible) and skin tones look terrible and suburnt in the light scenes you describe. Watched tombstone last night and could not stand it. I injected an updated version of TCL software as recommended through AVS Forums (https://www.avsforum.com/posts/63559375/) and going to roll back soon and see if it fixes the issue with dolby vision content. This TV has been a nightmare calibrating.
85QM851G, 5.2, UMIK-1, i1D3 OEM, Pi4b+ W/ Ted's PGenerator
#72 | Posted: 6 Nov 2026 16:12
Since the US version of the 85QM851G doesn't support internal LUTs, it's blindingly obvious that an external 3D LUT (via Lumagen or MadVR) is absolutely mandatory to fix these atrocious, sunburnt skin tones.
It would be incredible if we could somehow activate DDC support for these models, maybe via ADB commands, because relying on the standard manual TV controls to tame this factory EOTF curve is an absolute joke. Fighting with TCL's picture processing is a total nightmare.
Only 3DLUT, only hardcore!
#73 | Posted: 6 Nov 2026 16:31
Attached is a screenshot of what the TCL internal processing does to the color cube in ColourSpace. It's a total mess. TCL 85C855
Cube
Cube
Author twitt88
#74 | Posted: 7 Nov 2026 23:48
NebulaUK
This is pretty close to the approach I've settled on after quite a bit of testing with my TCL QM7K.
I start by finding the largest window that still maintains essentially the same peak luminance as a smaller window on black. On my 75" QM7K with LD set to Medium, that was around 16%, though I imagine this will vary with panel size, model, firmware, etc.
Once I've established that baseline, I gradually raise the background from black, just enough to keep the surrounding dimming zones engaged, while checking that peak luminance remains close to the original measurement. The idea is to keep the backlight active without introducing enough additional screen loading to significantly suppress peak brightness. This is for HDR where I calibrate directly against PQ as well as for DV where I use DV Calibrate. For SDR I still follow the tried and true, LD off, full field, then enable LD to Low for viewing. Has held up well in content... well, as well as to expect for a TCL FALD
I've also been experimenting with a Python passthrough using ColourSpace's Network Server to calculate dynamic background RGB values based on each measurement patch, essentially creating a constant-APL-style pattern.
Obviously, none of this eliminates the inherent variability of TCL's local dimming, but I'm finding this has translated pretty well to real content and a pleasing image overall.
Author twitt88
#75 | Posted: 8 Nov 2026 15:09
I agree that an external 3D LUT would certainly help with color mapping and other repeatable errors, but I don't think it addresses the underlying issue with TCL's processing. At the end of the day, the local dimming algorithm is still operating inside the display regardless of whether the signal comes from a Fire Stick, Apple TV, Lumagen, madVR, etc. A LUT can correct a predictable response, but it can't necessarily compensate for an algorithm that's constantly changing its behavior depending on the scene.
Interestingly, I'm seeing almost the opposite of the sunburnt skin tones mentioned above on my QM7K. In darker scenes, I get what appears to be a loss of saturation along with a blue/magenta push, particularly in faces. Sometimes it gives otherwise neutral scenes an almost cold, horror-film appearance. With local dimming disabled, the white point and color reproduction are considerably more consistent which can be fine for SDR but no one wants to watch HDR on a FALD display with local dimming disabled ha
That's really been my biggest takeaway from calibrating this TCL. Obviously, FALD is inherently challenging, but TCL seems to compound those challenges with some questionable processing and color-mapping behavior. I've managed to get excellent measured results, and the overall image can look very good, but getting those results to translate consistently into real content is another matter.
Ultimately, I think the goal is to minimize the compromises rather than expect perfect accuracy across every scene. At least that's been my experience with the QM7K.
 TCL TV calibration.
Members - 1 [ HeBer_nl ]
