Calibration Client
#1 | Posted: 30 Oct 2026 16:16
We've been working on a new Calibration Client, that is both a software variable bit depth and HDR aware TPG, with Light Illusion's Cal Images in-built, as well as enabling integration with external Hardware, such as video cards from AJA and Blackmagic.
It can be controlled locally, and connects to ColourSpace via the Network Server.
  • AJA - Kona, Io, T-Tap and Corvid cards
  • Blackmagic DeckLink and UltraStudio cards
At present, the program is undergoing Beta Testing.
For more information see the Calibration Client website page.
Calibration Client
Calibration Client
Author ColorCal Male
#2 | Posted: 31 Oct 2026 09:27
I might be wrong but that looks like an advanced alternative to Calman's Virtualforge with more options and capabilities?
I have both AJA and BMD hardware from my postproduction days can I test?
#3 | Posted: 31 Oct 2026 10:32
ColorCal
I've emailed you directly.
But yes, you are basically correct.
#4 | Posted: 2 Nov 2026 13:06
If any other ColourSpace users have any of the following AJA/BMD hardware, send me an email for a 5-Day test license of the new Calibration Client software system.
  • Blackmagic - DeckLink and UltraStudio cards
Author danielv Male
#5 | Posted: 2 Nov 2026 20:20
Hi Steve
That's great—if possible, a Mac version would be awesome. I use CalibMate, but the new Calibration Client can do a lot more.
Daniel
#6 | Posted: 3 Nov 2026 12:29
danielv
For Mac TPG and BMD video card integration I would checkout PatternSpace, as Mac has some very different requirements.
Author Charlie V Male
#7 | Posted: 5 Nov 2026 09:25
I think what danielv is referring to is that CalibMate is a native macOS app. For those of us who use a Mac as a host for a Windows virtual machine (using Parallels, for example) and run ColourSpace on that same computer, having a native macOS version of Calibration Client is extremely useful as an alternative to CalibMate. This is especially relevant for those of us using BMD video cards with SDI output.
One feature request I have for Calibration Client is the ability to use RGB 4:4:4 output through the BMD or AJA video card, rather than being limited to YCbCr 4:2:2. We have workflows where RGB 4:4:4 10-bit SDI is a strict requirement.
Thanks!
#8 | Posted: 5 Nov 2026 10:27
Actually, we are about to do a new Beta update with RGB 4:4:4.
And as the website pages states, a Mac and potentially Linux version are in the plans.
#9 | Posted: 5 Nov 2026 12:10
We have a new Beta with RGB 4:4:4 operation.
The website page has been updated too.
For anyone with AJA or BMD hardware that would like a 5-Day Beta Test license, please let me know.
RGB 4:4:4 Option
RGB 4:4:4 Option
Author danielv Male
#10 | Posted: 5 Nov 2026 13:02
Charlie V:
That's exactly my point. Nicolai from Calibmate has stopped selling it due to technical issues with its integration into ColourSpace. It works for me, but there are bugs. A native Mac tool directly from Lightillusions would therefore be great. It's no fun when a profiling session crashes halfway through.
Daniel
Author bazsko Male
#11 | Posted: 5 Nov 2026 17:37
Just tried out the basic version on the new Calibration Client. I get far more reliable results with it than with Dogegen. It immediately indicates whether I have an active ICC profile applied and reminds me to revert the color profile to the default, which is also a handy little feature. Not to mention, it's far easier to switch between SDR and HDR patches than with Dogegen, as you don't have to type those commands manually - there's a handy little GUI for that. The client also reads the monitor's EDID, which is super useful for HDR measurements. This is so far the best TPG software I've tried yet.
Author JNagy Male
#12 | Posted: 5 Nov 2026 21:17
Reading up on Calibration Client and it sounds great. I noticed on the Video Card page it specifies that BlackMagic Mini Recorder cannot be used, as it is input only. I'm assuming the Blackmagic Design UltraStudio Mini Monitor 12G can be used, as it is output only. Does the supported video card need to have both input and output, or output only is sufficient?
#13 | Posted: 5 Nov 2026 21:28
The BMD UltraStudio Mini Monitor 12G is a Thunderbolt input, video output device, so should be exactly what Calibration Client is designed to work with.
I've updated the User Guide to make that more obvious.
We are still in Beta Testing at the moment, so we are still updating things.
Just did a new release...
#14 | Posted: 14 Nov 2026 19:26
Along with all the work being put into PiTPG we have been doing additional development for the Calibration Client.
We have just pushed a new Beta Test version to our testers with BMD and AJA hardware, which included a range of new capabilities and options, not just for the hardware integration.
  • 8-bit patches in YCbCr are now exact on AJA and Blackmagic cards: 8-bit patches are converted at 8-bit, so an 8-bit analyser reading matches the standard tables exactly
  • Faster AJA RGB 4:4:4 on AJA cards with 12G routing (e.g. a Kona 5 on its 8K or 2x4K firmware): 1080p50/60 as single-link 6G, and 2160p up to 30 as single-link 12G
  • Calibration LUT: load a .cube LUT exported from ColourSpace and send everything - patches included - through it, on the window and the video card alike, to check the LUT outside ColourSpace
  • HDR Steps and HDR Steps Metadata Cycle patterns (exact 10-bit PQ grey steps, to see where a display clips)
  • A/V Sync test: a white flash and a 1 kHz beep once a second, in sync or 20-100 ms early or late - on a video card the beep is carried in its SDI / HDMI signal
  • PC delay correction for the A/V test in the patch window
The Calibration Client website page has been updated with the necessary information.
 Calibration Client
Members - 1 (hidden: 1)
