PGenerator – Connectivity Guide Wi-Fi & Bluetooth
Page  Page 5 of 5 :  « Previous  1  2  3  4  5
Author CQHandsome Male
#61 | Posted: 8 Apr 2025 05:00
It's been too long and I kind of forgot, it seems you need to be wired to your router before connecting to the bluetooth, so you don't have to be wired next time
I'm not sure if that's right but give it a try
Author jvisuals Male
#62 | Posted: 10 Apr 2025 02:59
CQHandsome
Thanks for the reply! I actually ended up going with the USB direct connect route. I bypassed the "network" and "bluetooth" options altogether and it seems to be working flawlessly. I should be in good shape from here. Thanks though!
#63 | Posted: 10 Apr 2025 11:08
jvisuals
The post I sent you contains information about connecting via Bluetooth (BT). You need to enable the access point to proceed.
If you use the public PGenerator ISO, the BT module is automatically enabled when you flash the ISO. However, it is disabled when you flash with Ted's ISO.
To enable the BT module, follow these steps:
1. Connect to the LAN cable.
2. Use the Settings 1.6 Template to enable the BT module.
3. Power off the device.
4. Remove the LAN cable.
5. Boot the device and wait for the black screen that appears after the scrolling test.
6. After that, try to locate the BT device.
