PGenerator – Connectivity Guide Wi-Fi & Bluetooth
Page  Page 4 of 5 :  « Previous  1  2  3  4  5  Next »
#46 | Posted: 1 Jan 2020 20:23
Any point with a negative value will be ignored when making a LUT...
Author Make73
#47 | Posted: 1 Jan 2020 20:30
Okay, but I can´t do new .bcs file without those bad readings, except maby open it with notepad and totally remove those three readings.
That was which confused me.
But if that´s the case, no need to make new 9261p profiling
#48 | Posted: 1 Jan 2020 20:42
With a -ve added to the bad points they will not be used when making a LUT.
So no need for a profile 'without' the points.
Author Make73
#49 | Posted: 1 Jan 2020 20:45
Understood
But I wanted profile without those 3 bad and it seems easy to make one
I didn´t waste over 4 hours, I´m happy.
This software is just superb, I´m glad Ted put me bought it
Author LegendOfFalcon
#50 | Posted: 12 May 2020 03:24
I have found that Malwarebytes can also block LightSpace from detecting PGenerator on the network (both when using PGenerator connected to a router via Ethernet and when using the Bluetooth connection). Closing Malwarebytes + allowing LightSpace through Windows Firewall is what I had to do for my setup to get everything working. Thought I'd pass that info along.
#51 | Posted: 12 May 2020 15:42
I don't use Windows Firewall at all as I'm behind a hardware firewall on our home network, but I do use Malwarebytes and haven't yet seen that problem with PGenerator on WiFi.
#52 | Posted: 12 May 2020 17:51
Are you using Malwarebytes free or the premium version? I still have an old lifetime premium license from before they switched to an annual subscription.
I went back and did some more testing, LightSpace can't see any available clients when the Malwarebytes Real-Time "Web Protection" feature is turned on. Instead of fully quitting out, I tried just turning that feature off and immediately after LightSpace will detect the PGenerator. I believe the real-time stuff is only in the premium version.
#53 | Posted: 12 May 2020 22:08
Premium. I did have to allow Device Control access through the McAfee firewall, but the RPi itself was recognized as being on my home network and works fine. Strange that we're having different experiences with Malwarebytes.
Author AmusedToD
#54 | Posted: 19 May 2020 23:41
Hi everyone, new user of LS here. Just starting to learn how everything works in the LS universe (with a big help from Ted along the way).
Anyway, I am experiencing a synchronization problem between LS and PG, which leads to huge reading errors by my meter (i1d3 Retail from 2016).
The errors can be reduced by changing the stabilisation numbers in the probe options (from 0.350 to 0.00), because they usually happen when a black stabilisation patch is displayed. The probe somehow picks up the black patch and that leads to big errors (over 30 dE).
I tried both the BT and direct LAN connection, but the issue persists. I have also created a Firewall rule for LS (inbound and outbound), but it makes no difference. My PG is updated to the latest software version.
Any ideas how to solve this problem?
#55 | Posted: 20 May 2020 07:36
Please use Extra Delay, as per the User Guides.
https://www.lightillusion.com/colourspace_manual.html#probe-options
and
https://www.lightillusion.com/calibration_issues.html#signal_delay
Author Narkose Male
#56 | Posted: 27 Apr 2023 11:34
Hey @ll
I have now bought Calman home for samsung as ColourSpace ZRO is getting on my last nerve. Whether I think I found out something this morning for the HDR 20 points calibrate, and then I had to work. But more on that in another thread perhaps. I just can't get a ColourSpace connection to PGenerator on a raspberry pi 400. The only thing that works is with a 1.5m USB C cable directly to the PC USB. But over router or wifi it is absolutely not possible. Wifi is not a choice for me either way.
I can ping the raspberry pi when it is only connected in lan with putty without packet loss.
I can connect the raspberry pi with PGenerator and Calman without any problem ONLY ColourSpace can't get it to connect.
I have disabled the router and windows firewall for testing and also added ColourSpace to the windows firewall but still no connection is possible. When I click on connect it immediately turns green and it says Available in the bar, that's it. I attach pictures.
This can ONLY be caused by ColourSpace. What else could you try? About USB C directly to the PC is s*** because only a 1.5m cable goes everything that is over 1.5m delivers too little power. I had once borrowed a USB hub and connected what has grilled my Raspberry pi. And I was lucky to exchange it.
So bomb everything you know into this thread as it seems I'm not the only one with the problem.
ColourSpace and PGenerator developers don't take my post personally if it doesn't click nicely. Sometimes you can use the nicest words and the translation makes it unkind to me after reading in English.
With love and best regards
Only network server
Only network server
PGen Lan CP Auto
PGen Lan CP Auto
PGen lan CP Custom
PGen lan CP Custom
PGen Lan CP off
PGen Lan CP off
PGen NET
PGen NET
Samsung GQ65QB95B, Denon AVR-X 3400H, ColourSpace ZRO+PGenerator 1.5 auf Raspberry Pi® 400, HDMI-Glasfaserkabel Playstation 5, XBOX Series X.
HIFI calibrated with laser rangefinder, decibel meter and Audyssey Multi EQ Editor. Unfortunately, I have to use a translation tool, [color=red]so sorry if something cannot be understood correctly[/color].
#57 | Posted: 27 Apr 2023 14:06
Narkose
We don't recommend any user use the WiFi module, as it will affect the device operation, it's a Pi problem, and it can't be fixed.
It's the reason the WiFi module has been disabled by default with Ted's PGenerator ISO.
Disable your WiFi module.
Have you tried the direct LAN connection?
Have you checked the BT connection?
You can find a lot of details about the connectivity options if you look at the first posts here:
https://www.avsforum.com/threads/dedicated-raspberry-pi-pgenerator-thread-set-up-configuration-updates-special-features-general-usage-tips.3167475/post-60090101
If you have any problem with ZRO or Ted's PGenerator, contact here:
https://displaycalibrations.com/contact_us.html
Author jvisuals Male
#58 | Posted: 2 Apr 2025 11:51
I realize this is an older thread, but I have similar Bluetooth connectivity issues as a previous post from Biasi back in 2019.
My PGenerator Raspberry Pi does not appear as a "Discoverable" device in my Bluetooth devices.
· I can confirm that BT is "Enabled" via the DeviceControl interface.
· I've attempted to create both Inbound and Outbound rules with my Windows Firewall to allow the connection of ColourSpace.exe.
· I've even turned off my firewall entirely to troubleshoot.
· I have several Bluetooth devices connected to my PC already, so the Bluetooth chipset itself doesn't seem to be the underlying issue.
· I understand that PGenerator has a Bluetooth IP address of 10.10.11.1, but I'm unsure where to input this data within my PC for it to be discovered.
Are there any other things that I can troubleshoot here?
For context, I'm working to build "calibration kits" to ship to my clients. I would prefer to connect the PGenerator via bluetooth so my clients don't need to mess with a direct connection to their router. And obviously, WiFi connections aren't particularly reliable to begin with.
Thanks in advance!
PGen not appearing
PGen not appearing
Device Connect
Device Connect
#59 | Posted: 2 Apr 2025 13:09
jvisuals
Have you followed those instructions?
https://www.avsforum.com/posts/60090102/
#60 | Posted: 7 Apr 2025 17:03
ConnecTED
Thanks for the response. I've gone through these instructions several times, but they don't seem to mention anything related to Bluetooth connectivity troubleshooting.
Again, from what I've seen previously in this current thread, I assumed it was a firewall issue, but I can't get to the bottom of it.
Just curious if you have any additional thoughts here, or if that's come up before. I can consider posting to the AVS Forum if the Light Illusion forum isn't the place to ask.
