PGenerator – Connectivity Guide Wi-Fi & Bluetooth
Page  Page 3 of 5 :  « Previous  1  2  3  4  5  Next »
Author biasi
#31 | Posted: 21 Dec 2019 22:37
can you connect to rpi with DeviceControl using 10.10.11.10 in device ip address field?
Author Make73
#32 | Posted: 21 Dec 2019 22:51
Actually got it work by bluetooth
Had to add rule for LightSpace to Windows Defender/Firewall, so new incoming rule, program, browse for LightSpace.exe, give rule...and same for outcoming rule.
You wrote it earlier but never done rules so I´m happy it works now.
IP for me is 10.10.11.1:43828
Author biasi
#33 | Posted: 21 Dec 2019 23:04
I'm glad it works now;sometimes it is necessary to install the rule in the firewall for the connection to work from the network manager
Author kniowsk1
#34 | Posted: 22 Dec 2019 22:21
I need some assistance in getting PGenerator updated via SSH in Putty. Not able to connect via the hostname "PGenerator". So, i typed in the IP address and when I use the username and password of PGenerator!!$ i get "access denied". I was able to connect via ethernet but I ran into a couple of bad meter reads I believe due to a network issue so I'd like to try Bluetooth instead.
Author biasi
#35 | Posted: 22 Dec 2019 23:17
the ip address for Bluetooth access is 10.10.11.1;have you used the username root as login?
Author kniowsk1
#36 | Posted: 23 Dec 2019 04:22
biasi
I was able to get the package update. Did not have the username as 'root'. Now, i'm trying to connect via Bluetooth and it's asking for a PIN in order to be able to add the PGenerator. I'm using an older USB BT adapter so wondering if that's the issue.
Author biasi
#37 | Posted: 23 Dec 2019 08:59
no pin is required because the device should be added in Bluetooth Personal Area Network but some dongle has not this option
Author kniowsk1
#38 | Posted: 23 Dec 2019 15:04
I will get a newer Dongle and give it a try. Thank you
Author kniowsk1
#39 | Posted: 23 Dec 2019 20:31
New dongle solved the problem. Must have been too old of a chipset and wasn't able to connect to the personal area network.
Author biasi
#40 | Posted: 23 Dec 2019 21:48
great news
Author Make73
#41 | Posted: 1 Jan 2020 08:50
If you get wierd reading with LightSpace and PGenerator, it may be wise to check you cat5 ethernet cables at first.
I had defective one from PC to router and after replaced it with new one everything works like dream.
Using RPi PGen again via ethernet.
At one 1000p verification got two meter errors but every other measurements went just fine.
edit:
At today got three bad measures with 9261p profiling
If I understood correctly what Ted wrote, with ColourSpace it´s possible to remove bad readings.
At next time I use 0.75 extra delay instead of 0.5.
#42 | Posted: 1 Jan 2020 18:34
You can 'remove' points with LightSpace.
https://www.lightillusion.com/profiling_manual.html#point_select
Just make any value negative, and it will be ignored when making a LUT.
https://www.lightillusion.com/advanced_lightspace.html#bad_points
(RTFM is always a good starting point )
Author Make73
#43 | Posted: 1 Jan 2020 19:30
I read that manual and even tried it to my bad 1000p verify where was also 3 bad (those were easy to find because of high dE) measures but no luck.
So you just need add one - to any value and it´s not counted.
But with this todays 9261p profiling, I have no idea what are those bad readings. Ted just told that problem is 3 patches and saw those lines at picture of ColourSpace.
But I´ll do that again when have 4-5 hours, no problem
#44 | Posted: 1 Jan 2020 19:49
Ah - this is where you need to start to 'think' about the tools within LightSpace, combined with an understanding of display profiles, and of calibration in general...
The thought process would be something like...
1) I need to see just points that have a high dE
2) But, the display profile is obviously from an uncalibrated display, so all points will have high dE values whne compared to a standard colour space
3) However... if the profile was 'mapped' to it's own peak RGB values, and the average Gamma value, the dE values for most points would drop...
4) So, I'd do that! Make a new colour space that is based on the profile's actual values.
5) And then use the dE >5 filter to see just the points that are over 5dE...
6) Then edit the points that have excessive dE values
This is a very good example of the benefits of the LightSpace approach, compared to the restrictive 'workflows' of the likes of Calman.
Author Make73
#45 | Posted: 1 Jan 2020 20:20
Yes, I was just a little lazy to find them
I had Rec709, 2.2 already. That was one of the first things Ted teached to me
So now I spotted those three high dE (over 10) and added - mark to front of every X, Y and Z value.
I saved it with new name and when open that new bcs it have REAL big dE´s, over hundred.
But You say that now when I go and convert it, it don´t count those three reading where are those negative - marks before values?
-Marko
Online now: Guests - 6
