M1/M2 Arm Mackbook Air & ColourSpace
Page  Page 4 of 4 :  « Previous  1  2  3  4
Author tbp
#46 | Posted: 7 Nov 2023 15:48
The i1Pro will not work in Windows for Arm ..
I just received an email from xrite that the i1pro 3 now has an interim workaround that lets you use it on a windows/virtual windows arm processor. For the i1pro 2 a firmware/SDK update will be needed. I only have access to an i1pro 2, however, and can't test it myself...
#47 | Posted: 7 Nov 2023 20:18
We have heard/seen nothing...
Author Itsguy Male
#48 | Posted: 8 Nov 2023 17:06
Edit: A crash when selecting 'Profiling', as explained elsewhere in this forum, is often an issue with bad/corrupt OpenGL drivers.
tallLeRoy:
@Itsguy you might try VMWare Fusion 3.5 with ColourSpace. The individual license is free and installing Windows 11 is very easy. The new version includes OpenGL support.
disclaimer, I have not tested this myself. I need to bother Steve each time I want to move my license to another machine or VM for testing.
I tried installing VMware Fusion and ColourSpaceZRO crashes the same way as under UTM, the moment the profiling window opens. HCFR seems to works fine in both systems though.
#49 | Posted: 8 Nov 2023 17:07
Then it is an OpenGL issue.
Have you searched this Forum for info on that?
VMware doesn't have the necessary OpenGL capability.
Edit: The latest version of VMware Fusion with the latest VMware Tool now has the correct OpenGL capability.
Author SiyoungCha Male
#50 | Posted: 1 May 2025 15:19
Hi everyone, I know this is an old thread, but I'm wondering if anyone has any updated information on i1 Pro 3 compatibility with Windows on ARM.
Previously, I tested ColorSpace on an ARM-based Windows system via VMware. The software ran fine, and the i1Display Pro worked without issues. However, the i1Pro 3 failed to connect, seemingly due to the lack of ARM-compatible drivers.
I've been hesitant to re-test because of the inconvenience of repeatedly transferring the ColorSpace license. Has anyone had success with the i1Pro 3 on native ARM Windows since then—or found any workaround or updated driver?
Thanks in advance for any insights!
#51 | Posted: 1 May 2025 15:22
There is no ARM driver for any i1Pro device.
Members - 1 [ PhilScheithauer ]
