M1/M2 Arm Mackbook Air & ColourSpace
Page  Page 2 of 4 :  « Previous  1  2  3  4  Next »
#16 | Posted: 6 Oct 2021 15:57
We think we have workout what the issue is...
Hope to have changes incorporated into the next release.
Author Vitaly Male
#17 | Posted: 6 Oct 2021 19:34
Hi Steve , i have same problem with parallels and colourspace . Can I have previous version of software?
#18 | Posted: 7 Oct 2021 07:41
We will issue an update as soon as we can.
As said, we think we understand the issue now.
As Windows For ARM is not an official Microsoft release as yet it is not presently guaranteed to work.
Author Matthias Male
#19 | Posted: 25 Nov 2021 03:47
These are good new to know, that ColorSpace and Apple M1 are on their way of working.
Next year I am expecting Apple to switch to the ARMv9 architecture. This is the moment, when the plot threatens.
#20 | Posted: 25 Nov 2021 08:46
The latest ColourSpace releases works with any Mac, using Parallels, etc.
#21 | Posted: 25 Nov 2021 09:51
Open minded question:
What would be necessary to port ColorSpace to Mac running without Parallels / VMWare?
Coding skills? Testing? A donation comparable to crowd funding?
#22 | Posted: 25 Nov 2021 09:53
It is development work we are already looking into.
Author ashish Male
#23 | Posted: 12 Feb 2022 23:33
I am running Windows 11 using Parallels on a MBP and I am not able to get Windows to recognize my i1 pro. It shows as connected but the error I receive is driver not recognized. When I try and update it manually as well Windows still will not recognize the driver.
I know you had mentioned in this forum post you were able to get your X1 pro working with a similar config. Would it be possible to share the driver you are using or a link to where I might be able to download it.
Thank you and I look forward to hearing back from you.
Ashish Hingorani
#24 | Posted: 13 Feb 2022 15:29
We have not tested the i1Pro Spectro with Mac Win11 via Parallels.
We have only use the i1Display Pro.
You will need to talk to X-Rite to see if the driver is compatible. It may not be...
#25 | Posted: 25 Jun 2022 18:21
Are there any news about getting a MacOS version of Colour Space?
Author Light Illusion Male
#26 | Posted: 25 Jun 2022 21:49
Sorry, no, we do not provide info on ongoing developments.
Author tsanga
#27 | Posted: 12 Aug 2022 19:25
I see many successful reports of using ColourSpace on M1 Mac + Parallels + virtual Win11.
Is anyone still using Windows 10 and have it working also?
#28 | Posted: 12 Aug 2022 22:23
As far as I know, there is no Mac M1/Parallels option that works with Windows 10...
Author tsanga
#29 | Posted: 12 Aug 2022 23:03
Thanks Steve, I see that now.
That means now I have to learn how to upgrade to Windows 11 on my very old PC before even entertaining getting an M1 Mac. Because I don't believe I can activate Windows 11 on a clean install straight from a Windows 10 license....
Author zmas Male
#30 | Posted: 15 Aug 2022 12:21
I'm using ColourSpace on my M1 MacBook Pro.
I did a 17ˆ3 profile of a client LG C2 TV. I started the LUT conversion of that profile and it's taking a very long time. Colourspace is completely frozen and while the processor is being used, it's only at 25% and there's no movement on the progress bar.
Other M1 users, what are your experiences when calibration creating luts on the M1? Does it take a very long time and is it normal for ColourSpace to freeze?
