M1/M2 Arm Mackbook Air & ColourSpace
Page  Page 3 of 4 :  « Previous  1  2  3  4  Next »
#31 | Posted: 15 Aug 2022 13:22
As we discussed via phone, the profile was totally invalid, due to a lack of Extra Delay while profiling.
(It does help to use the graphs to verify any profile for issues before trying to generate a LUT.)
Consequently, ColourSpace was trying its best to calculate a LUT based on invalid data.
It would have eventually generated a result - but it would not have been a viable LUT due to garbage-in = garbage-out.
Author bsbllfit7 Male
#32 | Posted: 5 Mar 2023 16:03
I have got the software running on my Macbook Pro utilizing windows 11 through parallels. The challenge I am having is the Colorimetry Research installer refuses to install the drivers for the CR100 and CR250. I have ran the driver install through the CRinstaller app, as well as just the driver installed. Everytime it just gives me a error that the installation has failed. Any advice on installing the drivers on the M1 Pro Macbook pro?
Author Anger Male
#33 | Posted: 6 Mar 2023 13:08
Are you trying to install CR software on macOS or Windows?
Author tallLeRoy
#34 | Posted: 30 Apr 2023 21:17
I am not having luck running ColourSpace ZRO version 1.0.0.1629 on an M2 MacBook Air. I am using VMWare Fusion 13.0.2 with Windows 11 Pro. I can activate my license, I get an immediate fail when opening the Profile Tool. I have attached the errors produced.
I prefer the VMWare Fusion 13 for Windows 11. Switched after Parallels wanted to charge me again after the first year. Shades of Calman. I could swear I asked for the permanent license.
ColourSpaceZRO_dbgrpt-1404-2.zip Attached file:
error when choosing Profile option
#35 | Posted: 1 May 2023 07:49
ColourSpace crashing when opening a Profiling window is usually caused by bad OpenGL drivers.
Try a Search on this forum for discussions on that.
Or click HERE.
Author nimrod7
#36 | Posted: 1 May 2023 08:41
tallLeRoy:
I have heard not great things regarding VMWare Fusion 13 in general.
For what is worth, I had limited success (i1Pro2 drivers being incompatible with ARM arch, but might not impact you) running ColorSpace on M1 via Parallels.
You can get Parallels via 1 time purchase for $129.99 to avoid subscriptions. I still run Parallels 17 on my Mojave. It supports limited number of cores, but it was superfast anyhow with ColorSpace. They have a trial you can use to see if everything working for you.
Author tallLeRoy
#37 | Posted: 1 May 2023 13:23
Thanks Steve,
I checked, VMWare Fusion 13 does not support Open GL in Windows VMs on Apple Silicon. You were exactly right.
Before I throw more money at Parallels, does the i1 Pro 2 now work in Parallels?
LeRoy
#38 | Posted: 1 May 2023 13:30
The i1Pro will not work in Windows for Arm ..
Author tallLeRoy
#39 | Posted: 1 May 2023 13:32
#40 | Posted: 9 May 2023 15:26
It has been conformed on another forum that ColourSpace will work on M1/M2 Macs using UTM and Win11 for ARM, so long as the Mesa 3D graphics library is also installed.
(Potentially via the 'perappdeploy' script from Github.)
Author tallLeRoy
#41 | Posted: 29 May 2023 21:58
I installed the Mesa 3D graphics library on my VMware Fusion 13.0.2 Windows 11 Pro VM. My M2 MacBook Air is the host.
I needed to search for perappdeploy on GitHub. I used mesa3d-23.1.1-release-msvc.7z from the releases page. There are four ways to install the OpenGL support with that release. Only using perappdeploy.cmd works, systemwidedeploy.cmd does not. Input the ColourSpace install folder, then the ColourSpace executable name. You must then select the x86 install when prompted, the other two installations will not work. I took the rest of the default options given for the install.
The good news is the ColourSpaceZRO works with my i1D3 and PGenerator. I hooked up both using a USB-C dongle that includes USB-A and Ethernet ports. I do not doubt that ColourSpace CMS licenses will also work using this method.
As expected, my i1 Pro 2 would not connect, I tried hard, but it would not connect. There may be more instruments that will not connect.
LeRoy
Author Itsguy Male
#42 | Posted: 3 Nov 2023 11:25
I've tried running ColourSpaceZRO on an m1 MacBook Pro running Windows 11 Pro ARM via UTM, following the above instructions and installing the latest Mesa 3D graphics library via perappdeploy. The app crashes as soon as Profiling is selected, with the attached report.
Any thoughts would be welcome!
ColourSpaceZRO_dbgrpt-2192-2.zip Attached file:
#43 | Posted: 4 Nov 2023 08:36
Sorry to say that as this is not a direct ColourSpace issue there is little we can suggest.
You would need to look for UTM technical support.
Edit: A crash when selecting 'Profiling', as explained elsewhere in this forum, is often an issue with bad/corrupt OpenGL drivers.
Author tallLeRoy
#44 | Posted: 4 Nov 2023 16:39
@Itsguy you might try VMWare Fusion 3.5 with ColourSpace. The individual license is free and installing Windows 11 is very easy. The new version includes OpenGL support.
disclaimer, I have not tested this myself. I need to bother Steve each time I want to move my license to another machine or VM for testing.
LeRoy
Author Itsguy Male
#45 | Posted: 6 Nov 2023 11:07
tallLeRoy:
Thanks for the suggestion LeRoy, I'll give that a try.
