New Software Releases Light Illusion Forums / New Software Releases /
Correlation Files for Calibrite/Xrite Colorimeters
Page  Page 4 of 9 :  « Previous  1  2  3  4  5  6  7  8  9  Next »
Author ChihHuangLin Male
#46 | Posted: 23 Feb 2025 13:26
Thank you, RollsRoyce. The output data indeed has a 1nm interval. What I'm unsure about is whether the instrument's spectral bandwidth of 5–8nm meets the requirements. If it is acceptable, I'd be happy to share the spectra I can measure.
#47 | Posted: 23 Feb 2025 13:35
As above, the reporting is 1nm
The measurement bandwidth is 5nm, or lower, depending on model.
Weirdly, the TOPCON SR-UL2 model specifies 5 to 8nm.
But yes, it is still worth providing Corr. File data from such a spectro.
#48 | Posted: 23 Feb 2025 13:43
Thank you Steve. Now that I know it meets the requirements, I'll upload and share the measured spectrum.
#49 | Posted: 24 Feb 2025 13:30
Correlation Files for Calibrite/X-Rite Colorimeters (24 February 2025 Update)
Added the following spectral correction (KarlKlammer took the measurement, thanks!):
JVC DLA-NZ500 (Laser Projector - Laser 100) - Qalif Spectro 1.8nm
Instructions
Download Link: ColorChecker-i1D3 Spectral CVS Files (24 January 2025)
#50 | Posted: 24 Feb 2025 13:51
ChihHuangLin
Oops! Looks like I misinterpreted the limited specs on that chart...
Author KarlKlammer
#51 | Posted: 28 Feb 2025 10:34
Here are two additional files for the next update.
Measurements were taken with a Qalif Spectro for the JVC DLA-NZ700 Projector with colour filter on and off.
#52 | Posted: 28 Feb 2025 10:42
Cheers Karl.
Much appreciated.
#53 | Posted: 28 Feb 2025 12:40
Correlation Files for Calibrite/X-Rite Colorimeters (28 February 2025 Update)
Added the following spectral corrections (KarlKlammer took those measurements, thanks!):
JVC DLA-NZ700 (Laser Projector - Laser 100 - Filter Off) - Qalif Spectro 1.8nm
JVC DLA-NZ700 (Laser Projector - Laser 100 - Filter On) - Qalif Spectro 1.8nm
Instructions
Download Link: ColorChecker-i1D3 Spectral CVS Files (28 January 2025)
#54 | Posted: 13 Mar 2025 14:38
I would like to provide the ASUS PA32UCR-K (Mini LED) Correlation File, measured with the UPRTEK MK550T 9nm.
https://lightillusion.com/forums/shared_files/storage/Colour_Spaces/asusfpa32ucr-k.zip
#55 | Posted: 14 Mar 2025 20:29
Correlation Files for Calibrite/X-Rite Colorimeters (14 March 2025 Update)
Added the following spectral corrections (ChihHuangLin took that measurement, thanks!):
ASUS PA32UCR-K (QD-Mini-LED AHVA IPS) - UPRTEK MK550T 9nm
Instructions
Download Link: ColorChecker-i1D3 Spectral CVS Files (14 March 2025)
#56 | Posted: 18 Mar 2025 11:51
Correlation Files for Calibrite/X-Rite Colorimeters (18 March 2025 Update)
Added the following spectral correction:
EIZO ColorEdge CG2700X (W-LED)- Colorimetry Research CR-250 4nm
Instructions
Download Link: ColorChecker-i1D3 Spectral CVS Files (18 March 2025)
#57 | Posted: 29 Mar 2025 19:52
Correlation Files for Calibrite/X-Rite Colorimeters (29 March 2025 Update)
FSI XMP270 (Gen3 QD-OLED) - Colorimetry Research CR-300 2nm
InstructionsInstructions
Download Link: ColorChecker-i1D3 Spectral CVS Files (29 March 2025)
Author SonyXP
#58 | Posted: 7 May 2025 18:13
Does anyone (following this topic) happen to have a Panasonic Z85A, has the equipment and can provide a correlation file for the display?
#59 | Posted: 7 May 2025 18:40
SonyXP
It's a non-MLA WOLED akin to the LG G4, according to RTINGS. Try the correlation file for that display.
Author SonyXP
#60 | Posted: 8 May 2025 10:45
Hey, thanks for the reply The G4-Series OLED panels do use MLA, the C4 doesn't. I tried to use the CX correlation file, aswell as the WOLED sample file. Both produce quite the same result in terms of deltaE. However, the Z85A (to my eyes) comes with a bluish/reddish tint, which I can't seem to correct this way. So it's either my perception or the limitation of this "budget" calibration solution, using an i1D3. Wanted to try a proper Z85A correlation file, if available - to see, if there's any kind of difference
