New Software Releases Light Illusion Forums / New Software Releases /
ColourSpace Main And ZRO Software Updates
Page  Page 11 of 22 :  « Previous  1  ...  10  11  12  ...  21  22  Next »
#151 | Posted: 18 Aug 2023 10:49
A new ColourSpace release has just been uploaded
ColourSpace Main
1.0.0.1717 – incremental changes
-- Added first iteration of Dell monitor integration, including internal probe
-- Improved layout of Point Info pop-up window
-- Corrected 1D LUT graph average line updating when Point Adjust used
Download is via the website Customer Log-In, as usual.
#152 | Posted: 21 Aug 2023 15:56
ColourSpace Main
1.0.0.1718 – incremental changes
-- Fixed Reports crash introduced in previous release
-- Fixed Reports graph dE display range not restored from save correctly
#153 | Posted: 8 Sep 2023 19:57
A new ColourSpace release has just been made (including ZRO)
ColourSpace Main
1.0.0.1743 – incremental changes
-- Corrected availability of Dell Hardware option
-- Added error message for failed .bpd Extract operation
-- Added catch to prevent identical names being used in Probe Matching
-- Added new Image Sequence Probe to PRO/XPT/INF
-- Updated Profile metadata format so library shows all info without profile being loaded
(To update an existing profile to the new format, open it, and re-Save)
-- Enabled use of keyboard Delete key to delete selected Library items
-- Enabled keyboard shortcut keys [ & ] to enable/disable TPG patches
-- Added warning when profile opened with Target colour space not available
-- Added Target colour patches to the pop-up Point Info window
-- Added ability to Export TCL DoVi .cfg file
(TCL HDR Matrix file Export to follow)
-- Enabled User Fonts to be used for Reports
(Contact Light Illusion for User Font processing)
-- Changed 'Rename' to 'Set Name' for Profile naming
(Profile Name can be set before performing Profiling)
ColourSpace ZRO
#154 | Posted: 11 Sep 2023 18:12
ColourSpace Main
1.0.0.1747 – incremental changes
-- Fixed Probe Match bug in previous release
-- Changed TPG Enable/Disable shortcut key to toggling the 'O' key
-- Added Status Window to Image Sequence Probe
ColourSpace ZRO
#155 | Posted: 12 Sep 2023 15:29
ColourSpace Main
1.0.0.1748 – incremental changes
-- Added ability to re-measure image patch frames in Image Sequence Probe
#156 | Posted: 17 Sep 2023 11:49
ColourSpace Main
1.0.0.1750 – incremental changes
-- Fixed Step option in Image Sequence Probe
-- Reverted TPG Enable/Disable shortcut key to back toggling the 'O' key
ColourSpace ZRO
#157 | Posted: 19 Sep 2023 13:21
ColourSpace Main
1.0.0.1756 – incremental changes
-- Fixed use of Manual Measure Presets for patch re-reading in Image Sequence Probe
-- Added Spyder X2 probe integration
ColourSpace ZRO
#158 | Posted: 9 Jan 2024 13:40
ColourSpace Main
1.0.0.1825 – incremental changes – BETA
This is an open BETA release– do not install unless you wish to participate in testing
-- Large refactoring of code base for new developments, including Point Adjust
(Consequently, there may be bugs & issues missed during our internal testing)
-- Added FSI XMP monitor integration
-- Corrected Point Info popup window data for Sub Space workflows
-- Improved Colour Engine operation for LUT Generation
-- Reinstated None option for Gamut Triangle Level
-- Fixed issues with DPS license not clearing profiles correctly on close
-- Corrected HSL operation in Manual Measure after ColourSpace closed/opened
-- Fixed issue with Probe Configure Matching window not showing
-- Improved Graph response to main Profiling Window size changes
-- Corrected License Level options for TCL TVs
-- Various fixes and improvements for Reports editing and layouts
-- Added first iteration of Vertical Groups to Reports Layouts
-- Fixed issue when identical names used in Probe Matching
-- Added TCL 3x3 Matrix export for HDR
-- Corrected Probe Matching not disabling when Active/Reference probe set to None
-- Added catch for Probe Matching if no probe name available
-- Added fix for Probe Matching issue when generating match file with CA310
-- Fixed issue with 'o' TPG enable/disable shortcut preventing 'o' being typed in IP address box
-- Added Topcon probe integration
-- Added first iteration of Point Adjust for Profiles
This release is an Open Beta, and users SHOULD NOT install unless they are happy to be a Beta Tester, and report bugs/issues back to us.
There will be Bug/Issues, so do not install if you cannot cope with such likely issues!
YOU HAVE BEEN WARNED!
#159 | Posted: 17 Jan 2024 19:34
ColourSpace Main
1.0.0.1840 – incremental changes – BETA
-- Fixed Virtual Probe min/max not showing values for Absolute colour spaces
-- Corrected issue with Point Adjust with white point and Absolute EOTF graph
-- Corrected Point Info selection jumping to zero point on Point Adjust change
-- Made change to PGen connection when IP address changes
-- Updated Manual Sliders to allow above 255 initial value for greater than 8-bit Resolution
-- Added Jeti specbos 2501 integration
-- Repaired broken Point Adjust operation in LUT Generation
-- Corrected dE L*u*v* in Reports
#160 | Posted: 19 Jan 2024 14:05
ColourSpace Main
1.0.0.1841 – incremental changes
-- Added option to force FCMM Probe Match rather than FCVM
-- Change to Admesy probe integration
ColourSpace ZRO
-- Added fix for occasional Probe Matching issue when generating file
#161 | Posted: 19 Jan 2024 15:44
Will that be added also in Colour Space Main?
#162 | Posted: 19 Jan 2024 15:48
Umm, please re-read the above...
#163 | Posted: 19 Jan 2024 16:43
Sorry, I have missed the main
Till yesterday FCMM was inferior and out of your interest. What has pushed to add this option (I 100% appreciate)?
#164 | Posted: 19 Jan 2024 20:42
A manufacturing partner asked to be able to compare the two...
#165 | Posted: 21 Jan 2024 17:19
ColourSpace Main
1.0.0.1843 – incremental changes
-- Added serial connection support for PGenerator
-- Fixed Probe Match mode saved with Profile
ColourSpace ZRO
