Generating 3DLUT with correct video-levels for madVR HTPC
#16 | Posted: 6 Jan 2026 15:32
Where are you watching content from the ENVY?
There may be a mismatch in the output settings of madVR or in the GPU.
What level setting is your madVR and your GPU outputting?
What patch scale did you use for the patch generation?
Author nathanware
#17 | Posted: 3 May 2026 07:41
I'm also curious about how to generate a 3D LUT for uploading to madVR HTPC.
If I profile my display using an Extended Range patch set, what is the right way to generate the LUT? Usually I use Normal Range with Normalise Code Range ticked. Are there any settings to generate the correct LUT from the start or will we always have to do a LUT adjustment for video scale? With an Extended Rage profile, would doing the video scale LUT adjustment use Pass Black or Pass Black SW?
LG C3, ColourSpace HTP, madVR HTPC
Author nathanware
#18 | Posted: 3 May 2026 07:56
Forgot to mention when I use madVR HTPC for viewing content, I have it set to output legal range levels and my GPU is set to full range. That way, the output retains BTW and WTW.
#19 | Posted: 3 May 2026 19:48
Profile with LEGAL, then generate the 3D LUT, and apply a videoscale passblack filter.
Author nathanware
#20 | Posted: 8 May 2026 18:15
ConnecTED:
That makes sense, thanks.
I am curious though, is there a big difference between profiling with Legal and then using the Pass Black filter compared to profiling with Extended and then using the Pass Black SW filter? It seems like with the Legal way it optimizes for the Legal range and then extrapolates above reference white while the Extended way optimizes the entire 16-255 range. Is there something I'm missing and doing the Extended way would be wrong with madVR HTPC? Maybe you only get the right gamma if you do it the Legal way?
#21 | Posted: 9 May 2026 12:02
By design, madVR PC needs LEGAL, LG OLEDs SDR needs EXTENDED.
Members - 1 [ twitt88 ]
