Use of LG TV Interactive White Controls
#1 | Posted: 2 Jan 2026 10:22
Giving here some notes about use of feature at the Subject.
The guide is at https://lightillusion.com/lg_manual.html
My intent is giving some suggestions about how using the interactive white controls, typical used in manual calibration.
Here how the interactive control page appears.
https://lightillusion.com/assets/img/lg-interactive-white-balance.png
Important to keep in mind:
  • There is nothing within the LG allowing interactive control values to be retrieved from the TV. So it is up to you exporting the related data for further importing.
  • The controls apply to the mode your TV is set.
  • There are 2 pages you can select depending you are acting either 2 points or 22 points interactive controls. Related commands (i.e. import/export/reset) are scoped to the the selected controls. Note: you have also 10 points control. Never tested as not in line to my practice done by tweaking first 2 points high and then 22 points.
I have found very comfortable (and time saving) to have a 22 grey scale running (repeating from manual measure) and tweaking on the LG interactive controls at the same time. For this approach I use the Diff EOTF page. But off course as alternative you can run the grey scale and tweaking the levels to are interested to.
#2 | Posted: 3 Jan 2026 11:12
Note: 2018 LG models have 20 point controls.
