ColourSpace Patch Colour window does not open
Author marianin1 Male
#1 | Posted: 8 Jun 2026 15:46
Hello,
I am using ColourSpace ZRO v1.0.1.2308 on Windows 11.
In Manual Measure, clicking the Patch Colour box does not open the floating patch window.
I have already reinstalled ColourSpace, reset the user data folder, tested one monitor, 100% scaling, English language, reinstalled NVIDIA drivers, and checked Defender. The probe connects correctly and test patterns work.
Is this a bug, or is there another setting required?
Thank you.
#2 | Posted: 10 Jun 2026 09:48
There is no such bug, so something with your PC/monitor configuration.
Does your PC think a second monitor is attached?
But what do you mean 'and test patterns work'???
#3 | Posted: 10 Jun 2026 19:41
The issue was resolved by resetting the configuration file. Here's how to reset it.
#4 | Posted: 10 Jun 2026 21:29
Then that means the Config File was somehow set to open the patch window off-screen, likely on a second monitor that was at some point connected.
Author phenaos Male
#5 | Posted: 27 Jul 2026 21:58
ConnecTED
This fix worked for me too (ColourSpace LTE). Same symptom — floating patch window and Test Patterns never opened, no trace in Task Manager or Alt-Tab. Deleting config.ini (C:\Users\<user>\AppData\Roaming\ColourSpace\config.ini) and relaunching resolved it immediately window regenerated with default position and spawns correctly now. Thanks for posting the original fix.
#6 | Posted: 28 Jul 2026 09:05
Then as above, that means the Config File was somehow set to open the patch window off-screen, likely on a second monitor that was at some point connected and removed after the Config File was saved.
Or potentially you have a 'ghost' monitor connected, via HDMI splitter, or WiFi/Bluetooth...
Online now: Guests - 6
