Users of PGenerator (free-public ISO or Ted's) will be able to connect to the newer ColourSpace versions as 'Network Server', and define the output resolutions/colorspace using the Settings Template in DeviceControl.
Using ColourSpace, you will set the patchscale, patchsize, bit depth, and, using the Settings Template, the resolution, output mode, colourspace output.
We will release a newer Template that will allow ColourSpace users to enable DoVi Verify, DoVi Calibrate, and YCbCr 4:2:2 REC.709/REC.2020 from DeviceControl.
Ted's PGenerator users will be able to inject patterns using
Ted's Template.
