DeviceControl can't connect to my LG OLED77G2
Author mirkoczekalla Male
#1 | Posted: 29 Feb 2024 07:40
I have the problem that DeviceControl unfortunately does not connect to my G2. I use the right IP address and I have also tried port 3000 and 3001ssl, but no luck. Strangely enough, I manage to establish a connection via bscpylgtv and it also works via the LG WhiteBalance tool, but not with DeviceControl.
Does anyone have any ideas?
#2 | Posted: 29 Feb 2024 10:55
Send a screenshot of your DOS window and a screenshot of when you modify the device for the LG TV.
https://displaycalibrations.com/contact_us.html
If your firewall is blocking DeviceControl, try to disable it and retry, or create a hotspot with your mobile phone and connect your system and TV to that network.
Author ddoonie
#3 | Posted: 7 Mar 2024 19:32
I'm running into the exact same issue, were you able to resolve? Also when trying to update DeviceControl it says Error.
I did create a hotspot with my mobile phone, also turned off the firewall.
#4 | Posted: 8 Mar 2024 11:08
ddoonie
The issue has been solved via email... after installing DeviceControl in C:\DeviceControl and Pearl in C:\Strawberry.
#5 | Posted: 9 Mar 2024 09:01
Thanks for the Info, i will try your fix.
