PatternSpace - macOS Test Pattern Generator for Display Calibration
Author caplaz Male
#1 | Posted: 1 May 2026 16:00
Hi everyone,
I'm Stefano, the author of LightSpace connect for (iOS/macOs/Android)
I'm looking for beta testers for PatternSpace, a next generation test pattern generator that runs on macOS. It has two main modes:
Pattern Library: a built-in library of GPU-rendered test patterns you can send to any connected display, including:
  • Solid fills, color bars (3/6/12/continuous, horizontal and vertical), step wedges, wipes, and gradients in RGB, HSL, and HSV
  • Geometry patterns: checkerboards, grids, lines, squares, points, distortion targets
  • Gamma checker and gamma lines patterns (per-channel)
  • Clipping patterns (high/low, per-channel)
  • Check patterns: overscan, convergence, resolution wedges, contrast, length, composite
Generator mode: acts as a pattern window target for external calibration software, receiving frames over the network using protocols compatible with:
  • ColourSpace
  • CalMAN
  • PGenerator (in alpha)
The app integrates with ColorSync — it can apply or bypass the active ICC profile on the output window, and it logs profile changes as you switch displays or reassign profiles.
What I need testers to check
  • Pattern accuracy and rendering correctness across different display types (SDR, HDR, wide gamut)
  • ColorSync behavior — does enabling/disabling the profile on the patch window behave as expected? Does it correctly reflect the active profile when you switch displays or reassign one in System Settings?
  • Multi-display workflows — selecting a target display, same-display mode (when the control window and patch window share one screen), display connect/disconnect handling
  • Network generator mode — connecting PatternSpace as a patch window target from ColourSpace, CalMAN, or PGenerator and verifying frames render correctly
  • General stability, edge cases, anything that feels off
Ideal tester profile
  • macOS user (the app is macOS-only)
  • Familiar with ColorSync and ICC profiles — you know how to assign profiles in System Settings, understand the difference between tagged and untagged output, and can tell when a profile is or isn't being applied
  • Comfortable giving specific, reproducible feedback
Stefano Acerbetti — developer of PatternSpace
PatternSpace
#2 | Posted: 2 May 2026 07:22
I have a Beta copy of this, and it is looking very good!
But I'm not a major Mac user, so Stefano need better assistance.
Who out there is a real Mac power user, and can assist Stefano?
Edit to say: As Calman have removed their UPGCI (Unified Pattern Generator Control Interface) capability, PatternSpace will not work with Calman - same as with LightSpace Connect.
Author Kuky
#3 | Posted: 3 May 2026 14:58
UPGCI works with Ultimate.
Author Light Illusion Male
#4 | Posted: 3 May 2026 15:22
True - if you want to pay that much, and keep paying every year...
Author Kuky
#5 | Posted: 3 May 2026 18:38
This PatternSpace can be something very interesting, unfortunately for the moment I don't have the time to give feedback.
I am using Ultimate/Patterns and it is nice so an alternative would be awesome.
#6 | Posted: 8 May 2026 15:00
There is now a dedicated website for the first Beta iteration of PatternSpace.
From there anyone interested in testing the Beta version can download the program.
There is also a Contact form for feedback on Beta operation.
#7 | Posted: 12 Sep 2026 09:05
Stefano is working on adding BMD DeckLink SDI support.
Obviously a very useful additional capability.
Contact Stefano via his PatternSpace website contact from to discuss!
