Please look at the
LUT Adjustment options in the
Interactive Manual.
All such operation is explained there.
But if you have any colour issues with any LUT - 1D or 3D - there is something wrong with the profiling.
And certainly any colour inverse says there is something very wrong.
You really should define what is going wrong with your workflow and correct it.
Also, when making a 1D LUT is is often better to use a Grey & Primary Ramp (maybe with Secondaries) , or even a full volumetric cube.
The additional measurements help when the probe struggles with lowlight accuracy.
