Show pre-roll in progress bar and stabilisation timer/indicator [Resolved]
Author ErikSwan Male
#1 | Posted: 11 Nov 2021 08:14
I have two related feature requests which are mostly UI/usability related:
1. It would be great if there was an indicator for the progress of the pre-roll sequence, if one is specified. Right now if you have a long pre-roll sequence, there is no way to tell the progress of the pre-roll sequence, because the pre-roll patches are not included in the patch count status bar at the bottom of the window:
2. It would be awesome if there was an indicator when the stabilisation patch is active, or better yet a timer showing the remaining stabilisation time. Once again, if you set a long stabilisation time there is no way to tell how much time is left or even that stabilisation feature is currently active.
I made a quick mock up in Photoshop to show what I am imagining - basically just add two additional sections to the bottom status bar showing the pre-roll sequence and the remaining stabilisation time:
#2 | Posted: 11 Nov 2021 09:58
Thanks for the feedback.
