Unable to find iDisplay3
Author zacreth
#1 | Posted: 7 Feb 2017 03:51
So the problem I'm having is I keep getting the message if I want to connect the virtual probe. I unchecked the virtual probe and clicked on the iDisplay Pro and the iDisplay 1/2/LT and when going to the display characterization it still prompts if I want to connect the virtual probe.
For some reason I can't get it to recognize the probe when it's plugged in. Any suggestions anyone?
Thanks!
#2 | Posted: 7 Feb 2017 08:16
Hi, try to uninstall LightSpace, delete the folder: C:\Program Files (x86)\Light Illusion\LightSpace CMS
Re-install latest LightSpace, and start LightSpace, activate your license, and then tick only i1Display PRO from meter list.
Ted.
Author zacreth
#3 | Posted: 8 Feb 2017 05:35
Hey Ted,
Still the same issue after following the steps you outlined. When I have the i1Display 1/2/LT, or the i1Display Pro I still get the prompt if I want to connect to the virtual probe. I can't get it to recognize the probe that I have.
Any other suggestions?
Thanks!
#4 | Posted: 8 Feb 2017 11:39
That says the i1D3 is simply not being seen by the laptop...
Actually sounds like an issue not related to LightSpace?
steve
Author zacreth
#5 | Posted: 8 Feb 2017 17:27
Hey Steve,
Well if I go into settings and look at the connected devices it shows up as iDisplay3 and I can use the probe with the manufacture's software and works but the calibration is horrible since there's more controls than the settings the software provides so in the end result I have a severely red hue.
I have a rev3 model is that makes a difference...
#6 | Posted: 8 Feb 2017 19:32
There is no such thing as a Rev3 model.
Only the original, and RevB.
And the X-Rite software is for ICC calibration, so will not work with most professional film and TV systems.
But there is something very strange with your connection issue...
Unfortunately I have no idea what that is.
There are no other reports of any similar issues.
But, try deleting the X-Rite software, as that may be 'hogging' the probe?
Author zacreth
#7 | Posted: 9 Feb 2017 04:25
Since I'm home and able to check it's Rev 2-B. I'll try to delete the X-Rite software and see if that helps.
Author zacreth
#8 | Posted: 9 Feb 2017 04:30
Aha. So what caused the issue was that I needed to remove the X-Rite Device Manager software that was installed. Once I removed that I was able to run the calibration interface and it asked if I wanted to connect to the i1Display Pro.
Finally!
#9 | Posted: 9 Feb 2017 12:28
Ok, that does indeed mean the X-Rite software was hogging the probe...
