Help Please with profiles not loading
Author pixelPusher Male
#1 | Posted: 21 Oct 2026 11:35
Hi everybody, i had a look through the forum and couldn't find a fix. I have a benQ SW271 monitor running out of a 2080ti via DP, I have a calibrite display pro HL all on win 11. I had issues with the monitor defaulting back to 8 bit on restart but i think i have solved that one. for the life of me i cannot get the profile i created to load when windows starts, i cant even get it to load manually, `the system defaults back to srgb, I've manually entered it into colocpl. uninstalled hidden monitors in device manager. i've deleted connectivity and configuration in regedit, set a 30sec delay in task scheduler. nothing i do seems to fix the issue. I also have a cheap prism_34"widescreen i use for sim racing and only have it on sometimes, it almost seems like windows thinks that my benq is the prism. I dont know i'm at a loss. can somebody please help
Author Alexey
#2 | Posted: 21 Oct 2026 12:14
pixelPusher
If you have a Benq SW271C monitor, it supports hardware calibration with the loading of 3DLut. If you came to this forum, you most likely already have the ColourSpace program purchased. The LTE license version of this program creates a 3DLut and writes it to the BenQ SW271C monitor; no ICC profile is required in the Windows 11 operating system.
The workflow is described here.
https://lightillusion.com/benq_manual.html
#3 | Posted: 21 Oct 2026 12:22
The BenQ SW271 (without the 'C') has no 3D LUT capability.
And the workflow pixelPusher is describing has nothing to do with ColourSpace or LUTs - it is an ICC workflow.
So unfortunately, there is really nothing we can do to help.
But ICC workflows are fraught with issues. See: https://lightillusion.com/what_is_wrong_with_iccs.html
#4 | Posted: 21 Oct 2026 14:01
Alexey, Steve
I've messed around with it a little more and the issue seems to be that windows refuses to load the profile at startup, or anytime, it defaults back to srgb
#5 | Posted: 21 Oct 2026 14:02
Thanks for the replies
#6 | Posted: 21 Oct 2026 14:07
Have you read the ICC info page linked to above?
ONLY the VCGT is used when no ICC aware program is running.
And a VCGT is not even a standard component of an ICC, and can only alter grey scale.
Author ColorCal Male
#7 | Posted: 21 Oct 2026 21:24
I use LI's SpaceMatch to load the required VCGT on Windows start-up if that helps.
That is just the VCGT not a full ICC.
The required ICC then gets used by the ICC aware graphics program.
#8 | Posted: 23 Oct 2026 01:01
ColorCal
Thanks for the tips. I think i solved it..... I had to get some third party softwares to load the ICC profile bypassing stupid windows. I think what was happening was that win11 was getting confused as to which monitor was which and then throwing profiles willie nillie. I'm getting delta E's of 0.5 ave and 1.2 max, its not perfect but close enough for now and the profile is loading and staying loaded. I'll let everyone know how it goes over the next couple days. thanks again evreybody :D
Author Light Illusion Male
#9 | Posted: 23 Oct 2026 07:16
As ColorCal says, you are loading a VCGT - not actually the ICC.
The VCGT is effectively attached to the ICC, so in a way a bit of the ICC is being loaded.
Also please follow our Forum rules - no discussion of software that is not from Light Illusion.
