LUT BOX Side Effect Risk with 17.17.17 Points?
Author Willian Aleman
#1 | Posted: 19 Nov 2016 15:15
Steve, thanks for the article on, What Is a LUT?
As a DIT moving from doing data manager to creating on-set Look LUTs for DPs, I would like to know what are the risk of introducing side effects, like banding, when working with LUT box limited to work with 17.17.17 points only vs a 33.33.33 points
Kind regards,
Willian Aleman
Digital Imaging Technician
NYC
#2 | Posted: 19 Nov 2016 15:35
A LUT will rarely, if ever, introduce banding just because it is a smaller cube size.
Actually, smaller LUTs are less likely to introduce banding as they tend to smooth-out colour effects/transitions...
The real issue with smaller LUTs is that cannot accurately represent rapid colour changes, as they have limited points as which changes/transitions can occur - obviously.
So if the colour eccetc you are looking to represent with a LUT is a subtle change smaller LUT will work perfectly well.
If the colour chnages you are looking to represent have a lot of intricate chnages, a smaller LUT may not be able to faithfully replicate them.
#3 | Posted: 19 Nov 2016 17:36
Willian Aleman
Thanks for your prompt and helpful response.
Following your explanation, to reduce the possibility of side effect on-set Look creation, I will use a LUT Box capable of processing 33.33.33 points only.
