TVlogic Monitors - LightSpace CMS Calibration
Author Margus
#16 | Posted: 3 Feb 2015 11:51
It seems like it depends from model to model.
But yes it is a bit different compared to "modern" monitors like FSI or Eizo.
I think even Penta has some interesting tricks in it's workflow like uploading LUT
with FTP client.
Sure not as simple as "modern" models have.
But now i see the problem.
LVM series is multi format on set monitors. Class 1 are XVM series.
Those are totally different in calibration sense even on their website and this also explains
why the workflow is so cumbersome.
Author andrea
#17 | Posted: 4 Feb 2015 09:25
Hello
Yes for LVM and XVM I've always used a custom made USB-Serial. Is a simple usb to RS232 adaptor and then a 9pin to 9pin that goes from the adaptor into the panel. I can gives schematic if someone want to solder one for himself
LEM calibration works via USB A-A and a simple software update to Calibrator 1.6.8 R1 solved the problem. There was some misunderstanding on which version of the software to use.
Margus, Can you calibrate the LVM via i1? I tried many times and I what I know is that Calibrator support the probe but they don't shake hands apparently.
LVM (243 for me) don't support LUT Manager. I think the whole seires is made like that.
Author Margus
#18 | Posted: 4 Feb 2015 09:47
Yes i could use i1 that i got from here LS shop. Worked out instantly.
It also seems to me that LUT manager does not play with LVM series.
I already have the cable schematics and i made my "twisted pair" cables yesterday.
It worked out nicely and was super simple to do if friends with soldering iron.
Author haasta
#19 | Posted: 16 Jan 2016 19:03
Im looking for TvLogic cable shematics guys.
I tried to connect this Tvlogic monitor models:
LVM 232 via usb _ working
LVM 246W via usb _working
this monitors cant be calibraited wit LightSpace. They just dont support 3D luts
XVM-245W i can't communicate with this monitor via any way.
RS232 to USB doesnt work
USB doesnt work ( Windows recognize monitor not as TVLogic monitor but as "CY7C68001"
I must write to Tvlogic support.
LVM-242W
Cant find cable schematics This monitor have VGA port
#20 | Posted: 16 Jan 2016 20:12
We've never had the cable pinouts...
The last cable we used was an SGI-Wacom cable, together with a null modem cable.
If I remember correctly, the SGI-Wacom cable was directional - it only worked one-way round.
Have you tried talking to TVlogic directly?
#21 | Posted: 16 Jan 2016 20:22
Actually - I take that back!
I've just found a document that seems to have the cable details...
I've added it to the TVLogic download from the Light Illusion website - download that again, and you'll find a new pdf file inside the .zip file.
I hope that helps.
Author haasta
#22 | Posted: 19 Jan 2016 09:19
Thanks Steve
Im looking for cable schematics for LVM 242W. It has different type port
But I talking with TVLogic directly now and they are very helpful.
They sent me USB drivers for XVM too so I think it will be good day...
Artur
#23 | Posted: 19 Jan 2016 09:40
Great - do keep us informed.
