TV Level Calibration LUT
Author EricCT
#1 | Posted: 2 Oct 2024 19:48
Hi all, the unity null LUT that comes with Colourspace is Full range levels, from what I can tell. Is there a way I can create a unity null LUT in legal TV level range? I thought maybe I could use the LUT generation tool with source as Null and Destination as Rec709, but don't think that does it.
I ask because our SmallHD 24" monitor has to use a calibration LUT and we only shoot in legal range video. I'm trying to upload a legal range null LUT to the monitor, then do a profile off of that. Thank you for any guidance.
#2 | Posted: 2 Oct 2024 20:01
You have to understand how LUTs are used in different signal range workflows.
There is usually no different with the LUT, as in most 'normal' usage the incoming signal is 0-1 range, with no actual understanding of TV legal or Data range.
When a LUT does need to be rescaled, you can use the Video Scale options in LUT Adjustment.
To make a new Null LUT you just use 'New' in LUT Management.
Author EricCT
#3 | Posted: 3 Oct 2024 13:38
Thanks Steve. I wasn't sure, as part of the menu process on the SmallHD is to choose Legal vs Full, then choose the LUT on the SD card. The whites are clipping in Colourspace when I do a Grey Ramp so I thought maybe it had to do with the range of the LUT. I adjusted contrast setting and backlight, to no avail. Thanks
#4 | Posted: 3 Oct 2024 14:00
That really means you need to ask SmallHD what the required LUT scaling is.
Otherwise you may be compensating for an error elsewhere in the signal path.
Author EricCT
#5 | Posted: 3 Oct 2024 14:16
Copy that, thank you
