Trying to calibrate a jvc nz500 laser projector
Author Fausto Male
#1 | Posted: 3 Mar 2026 09:37
Hi everyone,
I would like to rent the colorspace htl to create one o two 3D LUT to use with my htpc with MadVR connected to a jvc nz500 laser projector. Is there in the software a specific colorimeter correction for this projector? This is my first and essential question.
Thank you
Fausto
#2 | Posted: 3 Mar 2026 11:38
Yes, as per the list of available Correlation Files, there is a NZ500 file available.
(The list can be found following the Installation link on the Correlation Files thread.)
But be aware that no Corr. File can be relied on for accuracy - verify with SPD2Matrix first!
Author Fausto Male
#3 | Posted: 3 Mar 2026 12:22
Thank you Steve. I have seen the zip folder containing among others also the csv file for nz500. How could I add it to the correction files list in display cal?
Thank you very much
#4 | Posted: 3 Mar 2026 16:52
Fausto
What colorimeter are you using? Many colorimeters cannot use those correction files. They are for specific meters only.
#5 | Posted: 3 Mar 2026 17:05
Fausto
We very obviously do not provide support Displaycal, so have no idea.
Members - 1 [ HeBer_nl ]
