The Pro version and i1 DISPLAY Pro
Author jamiegau
#1 | Posted: 13 Jun 2015 23:54
I have a question on the Pro version and the i1.
In the comparison page, it lists..
i1Display 1, 2 & LT
Eizo Internal
Spyder4 & 5
i1Display Pro
i1Pro, and i1Pro 2
Out of all the probes listed, what would you suggest is most accurate, especially for projector calibration?
i1 Display Pro? It seems to have good reports/results by those who have them.
I imagine, if I get a better probe later, I can upgrade the software. Is there must of a difference in purchasing the next version up?
James
#2 | Posted: 14 Jun 2015 08:59
Hi James,
Out of that list the best would be a combination i1Pro 2 and i1 Display Pro.
You use the i1 Pro 2 to pre-calibrate the i1 Display Pro, and use the i1 Display Pro for the actual profiling.
See: http://www.lightillusion.com/profiling_manual.html#probe_matching
And: http://www.lightillusion.com/probe_use.html
And yes, you can upgrade LightSpace at any time - the cost is just the differential between the versions - no additional cost!
Author jamiegau
#3 | Posted: 14 Jun 2015 10:53
Interesting Steve,
Why is this? Is the i1 Pro 2 SLOW? Why not use it for profile too?
And how long would you expect to use a Probe before needing to get it re-calibrated to a know best value?
Ie If you did get a i1 DISPLAY Pro, how long should you expect it to stay relatively aligned?
You mentioned that the filters change over time..
What about the more expensive probes too?
James
#4 | Posted: 14 Jun 2015 13:04
Spectro probes are more 'accurate. but slow and can't read dark colours well.
So you use the Spectro to 'calibrate' the Tristimulus probe.
