LightSpace License Activation during Remote Desktop usage.
Author dwalme
#1 | Posted: 14 Oct 2019 19:59
I recently purchased LightSpace HTL. I ran a long calibration on my TV last night that was not finished when I left for work this morning. I connected to my laptop desktop remotely via Remote Desktop Connection to check the status.
I happened to close and then open LightSpace and I was prompted with the licensing dialog again. I entered my code and LightSpace said it was already registered.
Is this expected behavior?
I'm sure what I did is not common when calibrating, but I'd like to be able to use LightSpace through Remote Desktop if possible.
#2 | Posted: 14 Oct 2019 21:06
That will depend on the 'remote desktop' you use.
Different remote desktop systems operate in different ways...
It may also depend on the installation be a Local user, and the remote access being Admin, or similar.
There are a number of reasons that the license can fail when accessing remotely - so difficult to isolate your particular issue.
Author dwalme
#3 | Posted: 14 Oct 2019 21:43
I used the Remote Desktop Connection application built-in to Windows (standard Windows RDP protocol).
It connects me to the console display of the laptop as if I was in front of the laptop directly. Still logged in to the desktop session with my apps running as I left them.
#4 | Posted: 14 Oct 2019 21:59
That is unlikely to work - as it means some of the PC hardware will appear to have changed...
As the license locks to the PC hardware configuration, that will likely be an issue.
Author dwalme
#5 | Posted: 14 Oct 2019 22:59
Ok thank you.
#6 | Posted: 15 Oct 2019 17:36
I've tested Chrome Remote Desktop, and that seems to work.
Author dwalme
#7 | Posted: 16 Oct 2019 21:28
Thanks for testing that. I haven't used it but I will look into it.
