LG Oled G4 HDR - Calibration
Page  Page 3 of 5 :  « Previous  1  2  3  4  5  Next »
#31 | Posted: 30 May 2025 12:19
An LG TV that allows LUT uploads via USB or the service menu is not available.
Author cmal
#32 | Posted: 30 May 2025 16:31
he has no idea what he is talking about...
autsch...
...then I hope he will forward my questions to the next level...
do you think there could be something like a "repair-Firm-Ware" which LG could provide, or is the damage irreversible?
HTL
#33 | Posted: 30 May 2025 16:34
Please see the new ColourSpace release we have just made.
It should now show a warning message if the LG TV has no calibration capabilities.
#34 | Posted: 31 May 2025 00:13
It could be a function turned off somewhere in a deep level of the service menu.
If the repair center cannot find a method via the service menu, ask them to replace the main board with a board that has enabled calibration functions.
#35 | Posted: 31 May 2025 09:35
What does the latest ColourSpace release say when you connect to the LG and try to calibrate?
Author cmal
#36 | Posted: 1 Jun 2025 15:29
...my Friend is traveling, so I was not able yet to check... I will report as soon I have access... Thanks a lot
@ConnecTED
yes, we hope for a software solution; there is still no answer from LG-support;
HTL
Author cmal
#37 | Posted: 2 Jun 2025 14:45
@Steve
so, it is confirmed...
and if I open the user interface and click "Kal. on" I get the same error as before.
error
error
HTL
#38 | Posted: 2 Jun 2025 14:48
That does suggest there is no calibration option enabled within the TV.
But, it is not 100% certain that is the issue.
(See later posts on this.)
Author cmal
#39 | Posted: 2 Jun 2025 16:52
meanwhile the LG-Support came back to me.
it is a little bit unclear (problem with translation?) :
lose translation from my side: ' with this model the upload of a LUT with calibration mode would require the use of the Service Menu. But since the access (of the SM) for end users is against the policy of LG and one needs a "special remote control" () we need to contact a Service Partner"
they want to recommend one in our region.
We will see what he will do: replace the main board or really make some changes in the SM...
HTL
#40 | Posted: 2 Jun 2025 17:03
Again, suggesting Uploading LUTs via the Service Menu means they have absolutely no idea what they are talking about...
Author cmal
#41 | Posted: 2 Jun 2025 17:08
this thread is unfortunately a little bit mixed up;
the origin was the low maxLuma in HDR (the calibration issue came on top);
since I was working with the 65" G4 today in order to test the new CS version, I took the opportunity to recheck the HDR-brightness;
I can confirm that this device shows ~600 nits with 4096x2160 resolution and ~1500 nits with 3840x2160...
I could only speculate why...
HTL
Author cmal
#42 | Posted: 2 Jun 2025 17:10
...well maybe translation problems... maybe they wanted to say that in order to upload a LUT with this device some changes in the SM are needed, so the calibration mode could be activated...
we will see.
HTL
Author Optimalsettings Male
#43 | Posted: 12 Jun 2025 12:17
cmal:
when is the date?
Optimal settings
https://www.youtube.com/@DirkPajonk/videos
Author cmal
#44 | Posted: 12 Jun 2025 22:48
no feedback yet...
HTL
#45 | Posted: 13 Jun 2025 07:58
can you set the tv to hdr10 calibration mode with
bscpylgtvcommand 192.168.x.x start_calibration hdr_cinema
Optimal settings
Members - 1 (hidden: 1)
