Import colour space (Not Responding)
Author jpg Male
#1 | Posted: 9 Apr 2021 03:49
In ColourSpace when I do an Import Space i get the error above: Not Responding.
The program then goes into an infinite loop and I must exit.
What is the solution?
#2 | Posted: 9 Apr 2021 09:00
That suggests the Profile you are trying to import has an issue.
What is it, and where did it come from?
Author jpg Male
#3 | Posted: 9 Apr 2021 22:07
These are profiles that were built using LightSpace last year. If I select a file and try to open it using ColourSpace I get the error message:
The file size of the image must be 1920x1080.
#4 | Posted: 10 Apr 2021 08:10
Profiles are not Images - so it sounds like you are trying to load the wrong thing into the wrong place, with the wrong option...
Please have a look at the Interactive ColourSpace User Manual to see what the function you are using is really for.
https://www.lightillusion.com/colourspace_manual.html
Author jpg Male
#5 | Posted: 12 Apr 2021 20:18
jpg
Problem solved.
ColourSpace was waiting for a folder on OneDrive and OneDrive was not responding.
The error message about the image not being the right size also came from Windows.
Not able to see the profile I tried to open the file directly from Windows and Windows selected the wrong program.
If I try to open the profile using Open With ColourSpace, ColourSpace launches but the profile is not available.
#6 | Posted: 14 Apr 2021 07:37
You need to use ColourSpace to import the Profile.
No Profile can be 'opened' directly by ColourSpace from a different location, as it has to be in ColourSpace's library first.
Members - 2 [ Kuky, Steve ]
