How do i connect computer to LG C4?
Author eliasnemer92 Male
#1 | Posted: 26 Aug 2024 09:54
I went to but some cables today. the computer tech there said do not connect USB A to USB A or you will fry your Tv. How do i connect to My Tv for calibration purposes? also can i used the external TGP of colourspace? Im currently connected by Ethernet but Connection through color space is not working.
Using Colourspace LTE
Thank you,
Elias Nemer
#2 | Posted: 26 Aug 2024 10:14
https://lightillusion.com/lg_manual.html
You connect via the TVs IP address using a network cable connection, or WiFi.
And you can use any external TPG via the HDMI inputs, as per the User Guide above.
#3 | Posted: 26 Aug 2024 10:27
Thank you Steve
#4 | Posted: 26 Aug 2024 11:50
Hi Steve, Im still trying to connect to the tv. I used both wifi and ethernet, (separately). I pinged the tv and i got a reply. and made sure communication was up. Yet when trying to connect through colourspace it is giving me Error: No Host Defined. What would be the issue. I disabled firewall, and made sure they are on the same network and communication is up between tv and computer. Am i missing something?
Thank you,
Elias Nemer
#5 | Posted: 26 Aug 2024 12:40
That sounds like the TV is rejecting the connection attempt.
Or the IP address is incorrect.
You are not in Service mode on the TV, or similar?
#6 | Posted: 26 Aug 2024 12:49
No im not in service mode. the ip seems to be correct.. I manually edited the Ip 192.168.102.105 my computer address is 192.168.102.100.
When i ping the tv i get a response. so its weird. it shows its connected, but somehow not connecting through color space.
so most probably tv is rejecting? or maybe i should use default ip of the tv? is there a driver i need to install? im going to try connecting direct to the instead of having a router in between.
#7 | Posted: 26 Aug 2024 13:09
Hey Steve, First of all Thank you very much for you time. The solution was easy: Enter Network address into colourspace. Should have been more careful.
on another note what option should i select for Corr. Files Im using I1Display3 pro. TV is a LG C4. So currently i am on the preset Lg G3 WRGB Jeti 150.
Thank you very much
#8 | Posted: 26 Aug 2024 14:23
If there is no C4 Corr. File, then likely that will be the best match.
#9 | Posted: 27 Aug 2024 08:17
Thanks you!
Author Hustle Filmworks
#10 | Posted: 5 Feb 2025 22:32
Steve would this also work for the C2 panel?
Reading your correlation update in the user guide it seems using a correlation file with the i1 Display Pro may bring no real benefit as each devices hardware, although the same, returns different results?
Shaun
#11 | Posted: 6 Feb 2025 10:57
Please see the response to your other post.
But no, no Corr. File can be relied on for accuracy - check with SPD2matrix.
