Gamut Coverage on PC Monitor
Author mcg222
#1 | Posted: 11 Feb 2018 03:52
I have been experimenting the last few weeks with profiling using LightSpace DPS. I have created a 3D LUT for ITU-R BT.1886 using DisplayCal for a Dell UP2516D monitor (using RG Phosphor filter) and when I profile in LightSpace DPS (again using RG phosphor) I get a decent grey scale delta-e (<2), but my gamut coverage is ~93%. Without the LUT I get 99.3% gamut coverage in LightSpace but, of course, the grey scale delta-e is way off. Is this reduction in gamut coverage something that should be expected with a non color critical broadcast monitor, or is something funky going on?
Grant
#2 | Posted: 11 Feb 2018 08:00
Sorry, as we do not manufacture Displaycal we cannot comment on its level of calibration inaccuracy.
Author mcg222
#3 | Posted: 11 Feb 2018 15:31
Fair enough, Steve. Let me put it this way - LightSpace DPS reports that my Dell UP2516D monitor has 99.3% gamut coverage for ITU-R BT.1886 without any LUT on it. If I were to do a 3 day rental of LightSpace LTE and create a 3D LUT for ITU-R BT.1886, would a 7% gamut reduction be an expected result (ie for a non color critical broadcast monitor)?
Grant
#4 | Posted: 11 Feb 2018 15:32
Impossible to answer without knowing the volumetric gamut coverage of the display.
It all depends where the 'issues' reside.
You would have to perform a full volumetric profile and see where the actual colour resides.
Author mcg222
#5 | Posted: 11 Feb 2018 15:58
Thanks for the quick response, Steve.
Grant
