Data export!?
Author dashi
#1 | Posted: 24 Apr 2024 17:57
Please could I export the specific measurement data to Excel? For instance, exporting RGB color patches, reference XYZ values, and measured XYZ values?
#2 | Posted: 24 Apr 2024 19:34
All information is held in the .bcs profile, in an XML format.
You can import into Excel from there, as may users have already done.
For example, see the 'Genius Report' in the Addons page.
https://www.lightillusion.com/addons.html#adds-1
The Target values are based on the defined target colour space, and can be defined mathematically.
Author dashi
#3 | Posted: 24 Apr 2024 19:57
Thank you very much, Steve!But is this also possible for DPS versions? By the way, where are .bsc files usually stored?
#4 | Posted: 24 Apr 2024 20:16
No - as per the website info, ColourSpace DPS cannot work with .bcs profile files.
See the Features Matrix info.
 Data export!?
Members - 2 (hidden: 1) [ Steve ]
