Calibration for LG C3 on webOS 26 (firmware 43.21.71)
Author OliK83 Male
#1 | Posted: 21 Sep 2026 06:10
LG C3 on webOS 26 (firmware 43.21.71) — is LUT calibration supported?
I own an LG C3 (2023) that has been updated to webOS 26, firmware 43.21.71. Since the update, the calibration mode can no longer be accessed with the tools I used before.
Before deciding on ColourSpace, I'd like to confirm: does ColourSpace currently support direct LUT calibration of an LG C3 running this firmware — 1D and 3D LUT upload included?
If support depends on the ColourSpace licence level or a minimum software version, which one would I need?
Thanks in advance.
#2 | Posted: 21 Sep 2026 15:52
Author Alexey
#3 | Posted: 21 Sep 2026 15:56
Author titleexaminer92 Male
#4 | Posted: 21 Sep 2026 16:25
The most affordable license option for your needs would likely be a ColourSpace Home Manufacturer LG TV HTL license.
It will allow you to perform LUT calibrations on LG panels using consumer meters and PGenerator.
ColourSpace HTP
CR-100 / CR-250-RH / PiTPG
