BenQ Displays
Page  Page 3 of 4 :  « Previous  1  2  3  4  Next »
#31 | Posted: 25 Aug 2018 09:36
Some more news.
BenQ appear to have located and fixed the issue within their SDK!
We now have an internal test version of LightSpace using the new SDK, with updated BenQ firmware in the PV270, and all seems to be working as it should...
We hope to update the release of LightSpace with this new SDK in the coming week.
Any BenQ PV270 user will also need new display firmware from BenQ.
Note: According to BenQ only the BenQ PV270 display has suitable 3D LUT capability, so is presently the only BenQ display that can be calibrate with LightSpace.
#32 | Posted: 2 Sep 2018 10:12
The final BenQ integration has now been released in the latest version of LightSpace.
With the correct display firmware all is now working as expected (but it is very slow, so be patient!).
If any issues re encountered, make sure the correct FTDI driver is installed withing Windows.
(The dll is distributed within LightSpace, but may need to be 'installed' manually.)
Author larsdp
#33 | Posted: 4 Sep 2018 14:58
Do you know where the firmware is available? Can't find it on BenQs website and with a with a lightspace calibration how well does the display perform?
#34 | Posted: 4 Sep 2018 15:00
You'll have to contact BenQ directly I guess?
They have actually not informed us how they intend to distribute the firmware update.
And the PV270 is not at all bad when accurately calibrated.
Author larsdp
#35 | Posted: 5 Sep 2018 08:07
The firmware is (to my knowledge) not available on the official website yet. Hopefully soon.
But i got hold of a version direct from BenQ. You can download it here, incl. pdf with guide:
https://www.dropbox.com/s/ho8j8depapxn6vx/PV270 FW V2 update.zip?dl=0
Author teraman108
#36 | Posted: 28 Jan 2019 11:45
Hi, thanks for the download link, I tried the procedure but I didn't get my PV270 firmware updated. Created a usb stick as FAT32 and followed the instructions, but nothing happened when powering up the monitor. Any ideas what could be done?
#37 | Posted: 28 Jan 2019 11:51
Sorry, I think you need to talk to BenQ directly.
We do not provide any BenQ firmware ourselves, and cannot comment on firmware provided by third parties.
Author Thebird030
#38 | Posted: 12 Jun 2019 08:06
Hi all,
Can the Asus monitors even if not explicitly said use a 3D Lut through their calibration software. This software is used to recalibrate their monitors.
Kind regards
#39 | Posted: 12 Jun 2019 17:58
Thebird030:
Hi all,
Kind regards
You should ask ASUS directly.
#40 | Posted: 12 Jun 2019 18:12
At the moment there is no 3D LUT capability with ASUS displays.
But, ASUS have been in contact with us, and are looking into the possibilities.
Author HansWurst
#41 | Posted: 12 Dec 2019 09:04
Steve could you comment on the contradicting info about real hardware LUT BenQ is giving here?
https://www.youtube.com/watch?v=bz9y3db9vRI
See my comment there.
Thanks Hans
#42 | Posted: 12 Dec 2019 10:29
A hardware LUT is just a grey scale 1D LUT.
That is then combined with an ICC, or possibly a 3x3 matrix in the display.
See: https://www.lightillusion.com/icc_profiles.html
The only BenQ displays with viable 3D LUTs are the ones listed on our website, and that are therefore LightSpace capable.
https://www.lightillusion.com/benq_manual.html
That information id from BenQ themselves.
Author HansWurst
#43 | Posted: 12 Dec 2019 11:48
Thanks you so much!
Very detailed infos. Learning a lot here.
Did you by any chance test the SW321C and can validate this having a native 10bit (not 8bit+FRC) panel?
Hans
#44 | Posted: 12 Dec 2019 12:08
No, we did not test for the bit-depth.
Author HansWurst
#45 | Posted: 12 Dec 2019 14:19
Is the SW321C fanless by your testings?
Sorry for bugging you but this one seems a bargain at 2k USD...
 BenQ Displays
