BenQ Displays
Page  Page 2 of 4 :  « Previous  1  2  3  4  Next »
#16 | Posted: 28 Apr 2018 09:04
As far as we know, based on the information BenQ have provided us, that display doesn't have 3D LUT capability?
#17 | Posted: 28 Apr 2018 09:09
I should add, some news - we hope!
We seem to have eventually got a viable 3D LUT (combined with 1D LUT) working with our BenQ display and LightSpace.
We've just released a LightSpace update (a full release not a beta version) with the latest capabilities.
It can be downloaded via the normal website request process.
One word of warning, some of the first users to test this (and the previous ) version have reported that their displays report 'Does not have 3d LUTs'.
This may be a display firmware issue?
(LightSpace will interrogate all displays when connecting to them to make sure they have 3D LUT capability.)
We are waiting on information from BenQ regarding this.
Regardless, the calibration is working here, and BenQ have also tested and report the same.
Please do let us know any user findings.
Author Kuky
#18 | Posted: 28 Apr 2018 09:09
It surely does as per specs published and reviews.
Let's hope they did not lie in marketing material. I have 30 days to return.
I wouldn't even bothered if it didn't have 3D LUT.
#19 | Posted: 28 Apr 2018 09:31
If you connect the latest release of LightSpace to the display, it will tell you if there is a 3D LUT or not.
Author Kuky
#20 | Posted: 8 May 2018 20:04
Ok, I have the SW320 on my desk. It took only 13 days from the day I ordered....
Obviously I did not win the panel lottery so it will go back.
If you want me to verify if it works with Lightspace I need a beta or something as I don't own a copy of Lightspace.
#21 | Posted: 8 May 2018 20:10
From what BenQ have told us there is no point testing that display.
It has no 3D LUT capability.
If you want to contact BenQ and verify with them, please do.
Author Kuky
#22 | Posted: 8 May 2018 21:31
This is quite weird.
Benq marketing says all PhotoVue and VideoVue monitors have 14bits 3D LUT.
Maybe they have different types of implementation.
What is the use of developing your software to work with Benq monitors if it only applies to one model only.
#23 | Posted: 8 May 2018 21:39
When we started the development we were under the understanding that there were many displays within the BenQ range with 3D LUT capability.
We then discovered none had 3D LUTs, as we have commented previously.
We have worked for 2 years with BenQ to get something viable, and are now told only the PV270 display has a viable 3D LUT.
Author Kuky
#24 | Posted: 9 May 2018 12:54
Hmmm, so the "14bits LUT" in Benq marketing is actually an 1D LUT and a 3x3 matrix?
And the PV270 is the only one with "real" 3D LUT.
#25 | Posted: 9 May 2018 13:01
You will have to discuss that with BenQ.
All the information we have is as stated above.
We will be running full tests on the PV270 we have in the next couple of days, and will report the results.
Author Kuky
#26 | Posted: 9 May 2018 13:18
I fully understand that you can't comment.
This SW 320 is half magenta, half green. Moreover it has a diffuse black spot bottom center of the screen, sticking out like a sore thumb. Unbelievable.
Author AlexPro
#27 | Posted: 12 Jun 2018 08:15
I also received a SW320 and tested. However, I encountered a problem.
At any stage I can not unload the LUT.
I tried to upload and NULL.
I also tried to unload the LUT after profiling.
Every time I get error 'Does not have 3d LUTs'.
I studied the instruction https://www.lightillusion.com/benq_manual.html
But apparently something did not understand and did not see ...
I personally came to the representation of the company BenQ in Moscow and we watched with a technical engineer why this happens.
The firmware was the latest v003.
But the technical engineer does not know the program Ligthspace and therefore thinks that the problem of unloading LUT is on the side of the program ..
I continue to study this question, but unfortunately so far everything is very sad.
#28 | Posted: 12 Jun 2018 08:59
Alex, as I have said already in private emails, you have not 'read' the information on the page you linked to.
If you had read it, you would already know the answer to your question.
Following the 'instructions' is not the problem.
Reading the information is.
Author Matt_Sharp
#29 | Posted: 9 Aug 2018 02:09
Steve, or anyone with experience with BenQ, any word on the performance of the 32 inch model in this line?
Does it have the ability to upload 3d Luts from Light Illusion?
How well does it calibrate?
BenQ PV3200PT 32"
#30 | Posted: 9 Aug 2018 08:03
Please see: https://www.lightillusion.com/benq_manual.html
As it says there:
"The BenQ PV270 is presently the only display in the BenQ range with 3D LUT capability, and can therefore be calibrated via LightSpace CMS.
Note: BenQ must provide new firmware for any PV270 display to be 3D LUT capable, and due to an unresolved issue with their API/SDK have yet to release the new firmware."
 BenQ Displays
