3DLUT manipulation: 3D signal
Author alex_t
#1 | Posted: 15 Sep 2013 18:49
Hello.
Is there a simple way to generate a 3DLUT for 3D signal but from a display profile made in 2D mode ? For example the 3DLUT could take into account the offset due to the 3D glasses (but which offset ?).
Thanks.
alex
#2 | Posted: 19 Sep 2013 10:20
You need to read the patches though the glasses
Author alex_t
#3 | Posted: 19 Sep 2013 20:12
Hi Steve
Do you mean that I should do a new full profile through the glasses ? How can I do this with LS (Radiance allows doing this but I'm not sure that LS uses this feature) ? Or do you mean that I should read some particular patches to make an offset ?
alex
#4 | Posted: 19 Sep 2013 20:23
When I've done this in the past I put one lens of the glasses in front of the probe when profiling.
You may need to do either lens separately and then run two LUTs - one for each eye - if possible.
Author alex_t
#5 | Posted: 19 Sep 2013 21:10
Thanks Steve but it seems quite difficult. As I watch a 3D film about once a month I think that I'm going to keep the 2D calibration
alex
