Weird Dif EOTF with Default Unity LUT [Fixed]
Author Wolf91074 Male
#1 | Posted: 16 Sep 2026 14:34
Do the following
  • open a new profiling window
  • in the Probe tab, select Virtual Probe, connect with it and select i.e. UHD Rec 2020 as OETF
  • in the Settings tab, select the same Colourspace as Target, Default Unity as active LUT and Patch Scale/Resolution Legal/8bit
  • in the measurement tab, load the FullRange Patch (attachment) and measure it
  • you will get a weird Dif EOTF Diagram
  • now change Patch Scale to Full
  • and the Dif EOTF Diagram is as flat as it should be
So, what's going on here. An does this have an effect on LUT pre-evaluation?
The weird DifEOTF
The weird DifEOTF
The flat DifEOTF
The flat DifEOTF
FullRange.zip Attached file:
The Patch File
LG 65G59LS
Raspberry Pie PGenerator
xRite i1D3 OEM Dell
xRite i1Pro2 Rev. E
#2 | Posted: 16 Sep 2026 17:55
Ah - that is just associated with the Virtual Probe.
If you change the bit-depth too you will see the zig-zags also change.
Mind you, it probably should not do that.
We'll look.
#3 | Posted: 17 Sep 2026 22:20
Issue found and sorted.
It was indeed purely related to the Active Probe, Active LUT, and Legal Range combination.
Not an issue anywhere else.
Good find!
Will be fixed in the next release.
Members - 1 [ Steve ]
