Stab patch popping up when manually populating target min/max luma during measurements.... [Fixed]
Author titleexaminer92 Male
#1 | Posted: 22 Apr 2025 21:09
When using stab patches, if you decide to not use the Profile Luma Auto function to fill in the Target Luma Max / Min fields but instead use the up arrow to populate Target Max / Min in the middle of a sequence, the stab patch will immediately pop up on screen and take the place of the intended patch in the sequence.
This is similar to the earlier stab patch popping up when changing target gamuts in the middle of a sequence bug.
ColourSpace HTP
CR-100 / CR-250-RH / PiTPG
#2 | Posted: 22 Apr 2025 21:23
Good catch.
We'll sort that.
#3 | Posted: 23 Apr 2025 11:02
Fixed in the new release.
