Suggestions for upcoming updates to ColorSpace
Author Brho0m13 Male
#1 | Posted: 11 Oct 2024 00:48
Suggestions for some things that contribute to a better user experience on ColorSpace
When viewing EOTF in HDR in graphs the graphs are curves which makes it difficult to see and magnify near-black errors unlike in Calman where you can view a single line graph showing near black problems accurately
Numbers are not enough between measurement and the Target in Nearblack calibration in HDR
Linear graphs allow you to report and estimate the size of the problem to calibrate some signal in HDR for example with nearblack
This is the most important thing I attention to the linear graph of the EOTF in HDR as a Priority
Also if you add the possibility to match the max nits of the ST.2084 with the TV automatically by enabling it with a button
Instead of the user having to adjust the brightness value of the ST.2084 every time within the Pre set
Sort suggestions
1- Ability to use a linear EOTF chart instead of a curve to see near-black problem
2- Matching the max ST.2084 nits with the TV max nits Without modifying the preset st.2084 and creating a new preset
i can send a picture to illustrate what I mean by the HDR EOTF linear Graph via email
#2 | Posted: 11 Oct 2024 06:15
If you use the 'Absolute' option, you can view EOTF as an absolute graph.
And for your other comments, please update your ColourSpace to the latest version, and be sure to read the 'Changes' document.
#3 | Posted: 12 Oct 2024 15:17
Hi Steve
True today I checked it thank you i Use absolute error and i see absolute graph
But some point in thee nearblack are not visible and are clustered together. I hope to find a way to display them, perhaps because of the large number of point in graph. Need to adding the possibility to specify sub points to display them
Even though I zoomed in to the maximum, some points were hidden and collected.
For the second point
I saw the update details on the X app and told TED about it. I liked the feature, but TED apparently didn't test it and said the feature was to display the code value for HDR,
The both features are currently available
Great update
#4 | Posted: 13 Oct 2024 07:20
If any points are clustered together, it means the probe is reading them as the same colour - usually means the display is clipping, or the probe just can't read the low-light patches
#5 | Posted: 13 Oct 2024 16:26
The probe is CR-100 the best low light reading probe on the market
With maximum zoom Four points are collected, I don't know what they correspond to in the video signal ratio
the point 0 = 64,64,64 Target 0,0000 nits is normal to be at the lowest level
The point 1 = 68,68.68 the target is 0.0006 nits The probe read 0.0040 nits
The point 2 = 77,77,77 Target 0.0049 The probe read 0.0082 nits
The point 3 = 107,107,107 Target 0.0575 The probe reads 0.0241 nits
The difference appears in numbers, but I think it should appear in a Graph. That is, if I have a certain degree of Crush shadow details , the Graph should show the extent of the deviation from the reference line for correction
Perhaps a way could be found to represent the point error graphically through a feature even if the reading is close
Like Calman in Nearblack it shows the amount of shadow crushing up to 2.5% video signal in HDR
Author argonaut
#6 | Posted: 13 Oct 2024 17:30
It's obvious that EOTF graph zoom is inadequate in Absolute mode. Looking at ST2084 Rec2020 10-bit Legal code points 64-128 measured with Virtual Probe, here's normal mode at min zoom and Absolute mode at max zoom, both with point 128 selected.
Normal min zoom
Normal min zoom
Absolute max zoom
Absolute max zoom
#7 | Posted: 13 Oct 2024 19:54
As you have not used the point info dialogue to show the values, there is nothing that can be deduced from your screen grabs.
Author argonaut
#8 | Posted: 13 Oct 2024 21:43
If you can't see the individual points even with perfect measurement accuracy, the zoom level isn't sufficient ...
#9 | Posted: 14 Oct 2024 04:52
As above, As you have not used the point info dialogue to show the values, there is nothing that can be deduced from your screen grabs.
If you want us to take such feedback seriously, you need to provide valid information.
#10 | Posted: 14 Oct 2024 08:12
Hello Steve
I am the writer of the topic, different from the other person who is talking to you
I wanted to complete his words after checking Using a peak brightness of 1030nits for St.2084 Rec.2020 as a target with a virtual probe With absolute error enabled And zoom in to the maximum
In perfect condition for measurements
Points are collected from point 0 to 3 and at 4 the graph starts to separate the points clearly. Point 3 is just a little far away but cannot be seen clearly because it is crowded with the lower points
I'm trying to upload pictures to the site to show
Point 4 is clear and separate from the rest
https://ibb.co/PcP7VhR
point 3 close and unclear To a certain extent
https://ibb.co/kGQphz9
Point 2 It is aggregated and not clear at all in the Graph
https://ibb.co/mhDhxtN
point 1 Same thing
https://ibb.co/Kxf5Bss
Point 0 does not need to be displayed, it is at the lowest level
This is the same thing I see when taking real measurements using a real probe
We conclude from the graph that it is not Enough So if it was improved or a way was put in place to be able to see those points clearly, it would be good
#11 | Posted: 14 Oct 2024 08:51
That all suggest you are actually looking for Luna errors, not EOTF.
Better to use the Absolute option in RGB Balance.
#12 | Posted: 14 Oct 2024 09:51
I Look at the Luma errors in the EOTF Graph It is also used for this To see the EOTF track of the TV
I don't focus entirely on a flaw in the EOTF chart, it's correct, but the last points in Nearblack are not clear in the chart, and many use it to correct Luma errors on TV
I don't know exactly what you mean by Luma. Does it mean brightness errors with RGB balance? Both together. In general, Luma refers to brightness
To clarify I am looking for the TV tracking deviation from EOTF in the EOTF graph. This is used by reviewers to see how much the TV is deviating from EOTF tracking and fix it. The graph in Color Space is not sufficient to show this compared to Calman
It is useful from point 4 and above, but points below 4 do not show their deviation accurately in Graph
This is what the EOTF graph looks like with my LG G2 TV measurements and absolute error enabled
This is with zoom Everything is fine except that points less than 4 do not appear
https://ibb.co/55xJFHM
Thank you for showing me another way to see Luma errors on TV It's good for fixing EOTF with RGB balance errors but points 3 and below are a mess to represent as they show a big drop in the Graph
https://ibb.co/cxWr1jK
Different from the EOTF Graph where the deviation is shown in a logical and judgeable way
But thank you this helps me for calibration purposes more but it is not enough
I know Color Space is better than Calman in every way, but I strive to provide better and better experiences for users
But I think Calman accurately shows the EOTF deviation on a Graph down to the 2.5% video signal and you can see that deviation on the Graph
example
https://ibb.co/7bHc19M
https://ibb.co/TY2DCrQ
I always follow Vincent as he points out TV near-black problems either by 10% or more or a lot when pointing out near-black problems by 2.5% video signal and shows the amount of deviation in the EOTF graph
#13 | Posted: 14 Oct 2024 09:59
I think you are missing the point that any EOTF error is a Luma error, and will also be different in the three RGB channels - so the Absolute RGB Balance errors is basically the error you are looking at in the EOTF graphs.
#14 | Posted: 14 Oct 2024 10:34
No, I'm not missing the point but I told you that because you told me you weren't looking for EOTF errors, you were looking for Luma errors so I thought you meant that as if I was referring to Color Space errors in EOTF ST2084 in the reference drawing while I was talking about Luma representation errors and their deviation from EOTF
Thats The deviation is not shown on the graph due to the collection of points That's what I meant
So I know in advance that any errors in Luma are errors in EOTF
But you made them seem separate when you told me "That all suggest you are actually looking for Luna errors, not EOTF"
But thanks for telling me another way to see EOTF errors using the absolute error in RGB Balance it also doesn't need manual zooming to see the problems Compared to HDR EOTF Graph
Everything works but I just said my opinion that maybe improving the display of points in the EOTF Graph would be good for us
Showing The Nearblack Point lowest than 4 point is exaggerated when using absolute error in RGB Balance
#15 | Posted: 15 Oct 2024 09:20
No, the near black points are not exaggerated.
They are exactly correct for the Y axis scale.
If you have relatively large errors, the graph will show that.
But, we are thinking of altering the Y axis scale for Absolute plots.
