Solution for calibrating a monitor with Resolve 12.5 using VM Ware
Author Pedro
#1 | Posted: 20 Jan 2017 17:11
Hi all,
In my particular calibration workflow I'm using a Windows 7 VM with Lightspace running in the same computer than Resolve. I have two monitors attached to this computer:
1) My grading monitor, the one that I try to calibrate (connected trough a BM Ultrastudio Mini Monitor Thunderbolt interface + eeColor LUT box).
2) A GUI monitor running all programs (connected through DisplayPort)
When I'm calibrating the grading monitor all the applications (including Lightspace VM and DaVinci Resolve) run in the GUI monitor, and I need to switch between desktops within this GUI monitor to move from one application (Lightspace) to the other (Resolve). The issue that I found is that Resolve GUI needs to be visible on the GUI monitor in order to have the patches sent to the grading monitor. If Lightspace is visible on the GUI monitor Resolve doesn't send any patch to the grading monitor.
The workaround that I've found is to launch the calibration process in Lightspace then switch to Resolve while Lightspace is counting down to start the process. As far as I can tell this happens with Resolve 12.5, with earlier versions I could have the Lightspace visible on my GUI monitor and Resolve in the background, and the patches were sent properly. I presume that if you are using a different computer for running Lightspace you won't find this issue.
I just wanted to let you know in case anybody else faces this issue with a similar setup.
Cheers
Pedro
Author mhsmith
#2 | Posted: 8 Feb 2017 12:11
Hi Pedro,
Sounds like your Resolve is set to release the video IO when the application is not in focus.
To change it go to Project Settings/General Options/General Options and untick "Release video I/O hardware when not in focus".
Also I've noticed when VMware is in full screen mode, it can sometimes interfere with Davinci Resolve and delays can occur between the patch sending and patch receiving, so make sure VMware is in a floating window.
Hope that helps,
Marcus Hopton Smith
Author DeAlmeida Male
#3 | Posted: 27 Oct 2025 16:18
Hi Pedro and mhsmith,
Thank you for sharing all these years ago. I am facing the same issue in 2025.
After following the advices on this post I got the Characterization patches to show on the Resolve output.
However, no such luck with the Test Patterns in Manual Measurement.
Any idea why?
#4 | Posted: 27 Oct 2025 16:32
You CANNOT have 'images' held in a 3rd party program/location separate to Resolve show 'through' Resolve.
That is just standard logic on any image workflow.
So you download the CalImages from the Customer Downloads, and place them onto the Resolve timeline.
