Removing 1D LUT Component
Author Johnbar
#1 | Posted: 21 May 2021 16:29
If I wanted to remove the 1D LUT component from a 3D LUT what would be the best way to achieve that? Would I follow the same process that is documented under the Advanced Operation support guide and export the 1D LUT then do a subtraction? Just curious.
Thanks in advance.
Best,
John
#2 | Posted: 21 May 2021 16:30
We have recently add that info via the Look LUTs page.
https://www.lightillusion.com/look_luts_design.html
