Looking for Beta testers for Mac signal generator - CalibMate
Author Nikolai
#1 | Posted: 12 Feb 2015 23:25
I am writing a signal generator for Mac (with BMD Decklink, Ultrastudio or similar) that can talk to LighSpace via the network and create the colors needed for calibration.
I would like to have someone test this for me and provide feedback. You should be familiar with LightSpace and calibrate screens on a regular basis.
Please send an e-mail to nikolai@waldmanmedia.com if you want to help me test and provide usefull feedback.
Kind regards
/Nikolai Waldman
Author Damien Male
#2 | Posted: 17 Feb 2015 15:22
Hi Nikolai,
Have you had any luck finding beta testers?
I'm struggling to calibrate my monitor connected to a Mac. I haven't been calibrating monitors regularly, but I plan to if I can find an easy way to do so, and from what I gather that's what you're trying to do for Mac users.
I have LightSpace CMS installed on a PC which I use to run BM's Ultrascope and I have a new MacPro with a BM Decklink thunderbolt Ultrastudio (or something) connected to a FSI CM240.
If I can be of any help, pleae let me know.
Cheers,
Damien
PS I sent you an e-mail.
DoP, colorist, director
C-Side Productions
Geneva | Switzerland
#3 | Posted: 26 Feb 2015 10:32
You can see info on the application here:
http://www.niwa.nu/calibmate/
Author winfried
#4 | Posted: 21 Dec 2023 20:46
Will CalibMate also work (correctly) with ColourSpace?
On the website only LightSpace is mentioned.
Author winfried
#5 | Posted: 21 Dec 2023 21:15
And if so, will it have any advantage over the DaVinci Resolve pattern generator (with SDI 4:4:4 option on)?
#6 | Posted: 22 Dec 2023 08:47
I would recommend contacting the program developer.
As you can see, the last post in this thread was 2015.
Author Nikolai
#7 | Posted: 7 Jan 2024 17:19
winfried:
Hi Winfried,
yes it also works with ColourSpace. Today I released CalibMate 1.5 with a lot of new features.
Kind regards
/Nikolai
Online now: Guests - 7
