Limit Range - A unique approach to PQ HDR Calibration
#1 | Posted: 15 Apr 2021 22:40
One of the issues with PQ HDR is Display Calibration...
The present default approach is to disable the PQ EOTF, resorting to a 2.2 Power Law Gamma, and profile from scratch, in what is effectively super bright SDR mode.
And the very large EOTF change from gamma 2.2 to the PQ EOTF often makes for inaccurate calibration, especially with inferior calibration systems.
(ColourSpace actually doesn't suffer this issue.)
Additionally, some PQ HDR displays respond very differently when set to a 2.2 power law gamma in super bright mode, vs. using a PQ HDR EOTF...
But, traditionally, trying to calibrate PQ HDR display without removing the PQ EOTF means a lot of the profile data is thrown away, as it is above the peak nits limit of the display, as PQ HDR is an Absolute standard.
So, working with our friends at Flanders Scientific, we developed a PQ HDR calibration method that can be applied to a display with a fixed/burnt-in PQ EOTF, effectively calibration on-top of it, as we do with SDR calibration already.
(All SDR displays have a default 2.2 gamma EOTF, on-top of which the final accurate calibration is applied.)
This means the displays is actually profiled and calibrated while being in PQ HDR mode.
FSI have actually been using this approach for a while, using a slightly complicated manual workflow,
With the next release of ColourSpace we have introduced the first stage of a more simplified procedure.
After some user feedback, a second stage will be implemented, making the calibration approach even simpler.
The benefit is all profile data - the measured patches - are used in the final calibration LUT, and the display responds consistently throughout profiling and calibration..
The Interactive User Manual, and the Patch Scale & Resolution pages of the website have already been updated with overview info/instructions on the new Limit Range capabilities.
https://www.lightillusion.com/colourspace_manual.html
and
https://www.lightillusion.com/patch_scale.html
The same approach can also be used with standard SDR/HLG calibration, should there be a need to limit the patch range...
#2 | Posted: 12 May 2021 10:48
Flanders Scientific have released a calibration video explaining how the very unique PQ HDR calibration capabilities of ColourSpace can calibrate their XM310K 3000 nits display, with burnt-in underlying PQ EOTF.
#3 | Posted: 12 May 2021 22:05
Very cool.
#4 | Posted: 16 Mar 2022 16:51
The simplified version of this unique PQ HDR calibration capability will be active in the next ColourSpace update, including a new Increased Resolution PQ LUT option.
The relevant user guides have already been updated.
