If Colourspace crashes during startup
Author mecedo
#1 | Posted: 17 Aug 2021 08:53
On Windows 7 try to uncheck "Use visual styles on windows and buttons" option: Right Click "My Computer" | Properties | Advanced tab | Performance | Settings button | Visual Effects tab.
On Windows 10 ensure you have installed video card driver from hardware vendor not from Microsoft.
#2 | Posted: 17 Aug 2021 11:05
Windows 7 is not a Light Illusion supported OS.
We only guarantee operation on OS versions that are directly supported by Microsoft, and have not been depreciated.
Support for Windows 7 by Microsoft ended January, 2020.
Author mecedo
#3 | Posted: 17 Aug 2021 11:19
I know, but fortunately with unchecked "Use visual styles on windows and buttons" Colourspace works flawlessly on Windows 7 and gives the same results as on Windows 10
Author mrtickleuk Male
#4 | Posted: 19 Aug 2021 16:21
mecedo:
Glad you've found a workaround to whatever the problem is on that PC. I too am currently using Win7 (I fully realise it's not officially supported) for various reasons I won't go into here. As soon as I'm able to move to a new PC, I will, not least because 1366x768 feels cramped! Anyway - I don't personally need to untick the visual styles button, just for information - it works as expected. HTH.
