How Tracking My Work in BCS
#1 | Posted: 16 Aug 2019 08:19
After 6 months of LS HTP, I am full of Quick Profile ad Display Caracterisation I have ran. The only way I have for remembering about what they are about is basing on name and on date.
Maybe already addressed in Colourspace, but it would be nice to have:
1. Some info about the option I have used.
2. Some added free text. E.g,, my approach is to save my calibration setting in Excel file. It would nice if I could paste these info there (in a text format).
3. Something of similar would be nice for LUT manipulation, i.e. hystory tracking.
Regarding 2. I have found a way of introducing some free text in bcs files: You can add, using a txt editor, free comments on files in C:\Users\YOU\AppData\Roaming\Light Illusion\ColorSpaces. The format is <! TXT>. I have to do that there, as it does pass through LS export/import, but anyhow, for my needs, it is better than nothing. For my needs, I would use it for adding a rerence to the excel file descriving my related calibration settings. I have not done full testing, but it does not look disturbing LS further elaboration.
#2 | Posted: 16 Aug 2019 13:31
Annoyingly, making the library more interactive is not as simple as you would think.
So it's a no-no for LightSpace.
But, ColourSpace will have more options - but not all at once (not when first released).
#3 | Posted: 16 Aug 2019 17:37
Never thought it is easy.
Anyhow my one is a quick and dirty way to have something, that's why I have posted here.
Indeed I was quite curious about what is boiling in ColourSpace ,,,,, I saw something and it looks appealling, I will stay tuned
