HDR Profiling - Metadata Injection
#1 | Posted: 29 Nov 2019 10:38
For HDR10 TV profiling, HDFury can be used for HDR10 metadata/AVI infoframe injection with most patch generators.
Using the HDFury GUI add the required custom HDR10 Metadata:
(Always tick the REC.2020 flag):
Custom Metadata (P3 Primaries, 0.005 Black / 1000 nits Peak / 1000 MaxCLL / 400 MaxFALL): 87:01:1a:74:02:00:c2:33:c4:86:4c:1d:b8:0b:d0:84:80 :3e:13:3d:42:40:e8:03:32:00:e8:03:90:01
or
Custom Metadata (P3 Primaries, 0.005 Black / 4000 nits Peak / 1000 MaxCLL / 400 MaxFALL): 87:01:1a:b0:02:00:c2:33:c4:86:4c:1d:b8:0b:d0:84:80 :3e:13:3d:42:40:a0:0f:32:00:e8:03:90:01
Custom AVI InfoFrame:
For For PC/Laptop with HDMI 1.x output or PGenerator, set output RGB-Data and patch scale 16-235 while for AccuPel and DVDO AVLab set RGB-Video output with no patch scale:
82:02:0D:AE:00:E8:64:10:00:00:00 for 1080p60 RGB
82:02:0D:AE:00:E8:64:20:00:00:00 for 1080p24 RGB
For DVDO AVLab, as an additional option RGB-Video 2160p24 8bit output can be used:
82:02:0D:AE:00:E8:64:5D:00:00:00 for 2160p24 RGB
For PC/laptop with HDMI 2.0 output, RGB-Data and patch scale 16-235 can be used if required:
82:02:0D:AE:00:E8:64:51:00:00:00 for 2160p60 RGB
