ColourSpace Reports
Author nlucena Male
#31 | Posted: 18 Jul 2023 20:31
i will give it a try. i have been using mikis Genius report witch i do like as well but would be nice to learn how to do my own reports.
#32 | Posted: 2 Mar 2024 18:39
Here my example report with dE2000, ITP & L*u*v numbers.
Before_After_Portrait with I.zip Attached file:
Before_After_Portrait with ITP & Luv v1
dE numbers
dE numbers
dE Axes values
dE Axes values
Author PhilipW
#33 | Posted: 19 Apr 2024 18:26
Would it be possible for ColourSpace to use the Profile name selected in the report generator to create the first part of the filename, with the 'report' suffix; eg JVC67332324 Post-Cal report ?
As someone who calibrates a number of displays, it would save me from having to keep remembering to go back into the set name window and copy it.
Users can obviously change it in the save dialog box, if you want a different name.
#34 | Posted: 20 Apr 2024 13:10
PhilipW
That may indeed be possible to add...
 ColourSpace Reports
