Can't activate ColourspaceZRO - "Disabled network adapters" [Fixed]
Author robertorgf
#16 | Posted: 19 Jan 2026 15:17
No, but in the past I had a VM in the notebook, but I removed it and vmware in the past. ( And I've cleaned all network devices related with it, I've been three days with Gemini trying to clean all network devices, reinstalling drivers, reseting network, etc).
#17 | Posted: 19 Jan 2026 15:19
Could easily be the source of your issues...
Author robertorgf
#18 | Posted: 19 Jan 2026 20:04
Hi, I've been able to solve the issue. I'm sharing it below, maybe it can help other people.
Here is the process:
1) Download the ISO: Go to the official Microsoft website and download the Windows ISO matching your version (Windows 10 or 11). You can use the "Media Creation Tool" and select "Create installation media" -> "ISO file".
2) Mount the ISO: Once downloaded, double-click the ISO file. Windows will mount it as a virtual DVD drive.
3) Run Setup: Open the drive and run setup.exe.
4) The Critical Step: Proceed through the menu until you reach the "Ready to install" screen. Make sure it says: "Keep personal files and apps". (If it doesn't, do not proceed).
5) Install: Click Install: The PC will restart several times.
This essentially gives you a fresh OS "under the hood" while leaving your user environment, licenses, and installed software exactly where they were. It's a great way to clear out driver/network conflicts without the headache of reinstalling everything from scratch.
Hope this helps anyone stuck in a similar loop!
Thanks for your help and fast responses.
#19 | Posted: 19 Jan 2026 20:16
You can do all that from within Windows -> Settings -> Recovery.
There are a number of options to Reset/Recover Windows there.
I did say you likely had a corrupt Windows installation and/or driver previously.
Glad you have sorted it.
